UNL1MTD Posted June 5, 2007 Share Posted June 5, 2007 Anyone ever rig up some exhaust shielding to cover the turn in the down pipe that runs under the cab just before the cat? The cab get mighty toasty there and with no AC I figure this maybe well worth the investment. I've never messed around with the stuff before and have no clue how hard it would be to install. I was looking to do something under the cab, opposed to say dynamat which would be under the vinyl. Anybody have any experiences with it or even better pictures? Link to comment Share on other sites More sharing options...
Pete M Posted June 5, 2007 Share Posted June 5, 2007 I thought about that once. Even went ahead and purchased some. But then decided against it since the truck was mostly for offroading and I wasn't sure what happens when the wrap gets all wet and muddy. :( Link to comment Share on other sites More sharing options...
UNL1MTD Posted June 5, 2007 Author Share Posted June 5, 2007 I thought about that once. Even went ahead and purchased some. But then decided against it since the truck was mostly for offroading and I wasn't sure what happens when the wrap gets all wet and muddy. :( are you talking about the stuff you wrap around your pipes? I was thinking more like the tin foilish stuff (techincal term). But I got no clue how it works. I'm going to stop in Advanced Auto and poke around. Hopefully its cheap. Link to comment Share on other sites More sharing options...
Pete M Posted June 5, 2007 Share Posted June 5, 2007 Yeah, the stuff I got was made of heat resistant fabric/glass/whatever. Definitely not foil. Link to comment Share on other sites More sharing options...
UNL1MTD Posted June 5, 2007 Author Share Posted June 5, 2007 stopped in Advanced and NAPA, neither one carriers any kind of shielding like I was refering to. Advanced carries the wrap stuff but its pricey at 45 bucks. NAPA mentioned that the only time they sell muffler shields is if it comes with the muffler. I guess I'm gonna just deal for now. Link to comment Share on other sites More sharing options...
Pete M Posted June 5, 2007 Share Posted June 5, 2007 You could try fabbing up a metal shield out of thin metal. That's all a muffler shield is. Just something to block/reflect the direct heat radiating out. Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 5, 2007 Share Posted June 5, 2007 Buy some stainless sheet and get it rolled to a nice countour. Header wrap isn't ideal on a street/trail rig if you ask me. It will destroy anything you wrap with it in short order. Link to comment Share on other sites More sharing options...
Mudshovel_009 Posted June 6, 2007 Share Posted June 6, 2007 get that heat shied floor insulation.... under your carpet. My mj cooks me out but........ I have not carpet. put new floor pans in and never put carpet back in. haha Link to comment Share on other sites More sharing options...
Pete M Posted June 6, 2007 Share Posted June 6, 2007 As many leaks as our MJs get, I don't advise putting anything under the carpet that might hold water. In fact, I recommend pulling up the carpet and removing the stock stuff that's underneath. With any luck it's not already a big stinky sponge. :( Link to comment Share on other sites More sharing options...
JeepcoMJ Posted June 6, 2007 Share Posted June 6, 2007 :agree: I remove my stock padding every time, and then put in ceramic insulator pads that I get from my grandpa's leftover stuff. it's some ceramic stuff he uses for building firefighter practice towers...they won't start on fire and don't hold moisture. idk what they are called tho... Link to comment Share on other sites More sharing options...
mfpdm Posted June 6, 2007 Share Posted June 6, 2007 As many leaks as our MJs get, I don't advise putting anything under the carpet that might hold water. In fact, I recommend pulling up the carpet and removing the stock stuff that's underneath. With any luck it's not already a big stinky sponge. :( When I pulled mine out that's exactly what it was, and man did it smell. :eek: I even had the truck in the garage for over a month and a half and it was still wet. I would say it's the prime cause of the rust in my floor pan. Link to comment Share on other sites More sharing options...
feerocknok Posted June 6, 2007 Share Posted June 6, 2007 Header wrap'll keep the heat down, but it keeps all the heat inside your exhaust causing other problems. Just get some thin metal and get it above the muff. Even an old computer case if you don't have any metal laying around anyways. Link to comment Share on other sites More sharing options...
UNL1MTD Posted June 6, 2007 Author Share Posted June 6, 2007 Found a company called Thermo Tec, they got tons of solutions. Looks like Summit carries their full line up, so that'll make ordering easy if I decide to do it. http://www.thermotec.com/ Link to comment Share on other sites More sharing options...
