Mudshovel_009
Mudshovel_009's Achievements
  1. Rebuild that 2.5 and I agree with upping the fuel pressure and tb, I even have a rare mopar performance cam and lifters I'm not using only has a few miles on it, would be willing to part with it. alway wanted to build a 300hp 2.5...... laugh but I can dream
  2. get that heat shied floor insulation.... under your carpet. My mj cooks me out but........ I have not carpet. put new floor pans in and never put carpet back in. haha
  3. ha ha ha ha ha, not being mean, but that's funny..... what plug did you pull out of tranny, only the asian trany has a drain plug, the chrysler trans does not, you must remove pan. Did you put the detent back in correctly? TRavis
  4. I agree with JeepcoMJ, however you will not need to replace evap, I do however recomend that it be flushed as well as the rest of system, but if parts truck a/c is still closed and you CLEANly take it apart and plug holes and spill no oil you should be fine. I do think you should replace any o rings you take apart and even though this is a r 12 system they adapt to r 134a just fine, don't mess with changing oil or fill fittings. just use a r 134a side can tap will acme r 12 fitting and fill her up, I'v done this to many a/c systems and have never had any problems. That's my two cents TRavis
  5. I have a two wheel drive jeep, I really think a 3 inch lift is not needed nor do I want to. I guess I could re work a oil pan if I had to. Loooking at my 86 4x4 MJ I could see a lift being needed. Just the cooling system is what I can't seem to come up with any ideas. Anybody ever seen a 3 core stock sized 4.0l radiator?
  6. I'm installing a Chevy 5.7L S/B Tbi motor and 700R4 in to my little 88 MJ. Wondering if anybody has any tips for me on what they found worked best as far as motor placement, what exhaust manifolds fit best and so on. My biggest question is the radiator. I messured and have a good idea where this motor is going to sit but I can't find a radiator with a power steering gearbox notch in it (ha Ha) Hase anybody tried the 4.0l radiator? Any tips or pictures would be awsome. Travis
