sinkrun Posted May 7, 2015 Share Posted May 7, 2015 Can a drive shaft be so rusty theres A danger of breaking. Its on a XJ it has VERY HEAVY scale compared to the one on my 89 MJ looks looks like new compared to this thing. Its not a wheeler just a driver. Link to comment Share on other sites More sharing options...
Megadan Posted May 7, 2015 Share Posted May 7, 2015 If it worries you that much, take it to a local driveshaft shop and get their opinion. Worst case scenario, they can build you another one for usually a fairly low price Link to comment Share on other sites More sharing options...
AeroNautical Posted May 7, 2015 Share Posted May 7, 2015 Yeah, wouldn't risk it. Taker her off, take it to a driveline shop and have a new one made. Retubing a driveshaft is fairly cheap, under $100 around here. Link to comment Share on other sites More sharing options...
Pete M Posted May 7, 2015 Share Posted May 7, 2015 what you're describing is fairly common, but not usually a structural problem. but when in doubt, stab at it with a screw driver and see how solid it feels. :thumbsup: Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 7, 2015 Share Posted May 7, 2015 Get an aluminum shaft made. :thumbsup: Link to comment Share on other sites More sharing options...
Megadan Posted May 8, 2015 Share Posted May 8, 2015 when in doubt, stab at it with a screw driver and see how solid it feels. :thumbsup: That's what she said? :brows: Link to comment Share on other sites More sharing options...
sinkrun Posted May 8, 2015 Author Share Posted May 8, 2015 Headed to the PNP Friday there $21.00 there if I can find a good one. Anyone know what years would be the same, its A 2001 XJ? Link to comment Share on other sites More sharing options...
Pete M Posted May 8, 2015 Share Posted May 8, 2015 avoid anything before 87. other than that, year matters not. try to find one with the same engine/trans. :thumbsup: Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted May 8, 2015 Share Posted May 8, 2015 Is there a difference between the dry output shaft with the rubber boot on the newer Xjs vs the shaft with the rear output seal on the older ones ? Link to comment Share on other sites More sharing options...
AeroNautical Posted May 8, 2015 Share Posted May 8, 2015 The newer transfer cases had a closed system, in which you could remove the rear driveshaft and not have it leak, letting you putt around front wheel drive if you wanted. I believe the splinage on the newer cases increased as well, you'll need a new slip yoke. Link to comment Share on other sites More sharing options...
Pete M Posted May 8, 2015 Share Posted May 8, 2015 are we talking about front or rear driveshafts? Link to comment Share on other sites More sharing options...
schardein Posted May 8, 2015 Share Posted May 8, 2015 Headed to the PNP Friday there $21.00 there if I can find a good one. Anyone know what years would be the same, its A 2001 XJ? I have a lot of experience searching parts at pic-n-pulls, and you will find the rear driveshafts are bent when they move the vehicle into place with a forklift. Link to comment Share on other sites More sharing options...
sinkrun Posted May 8, 2015 Author Share Posted May 8, 2015 are we talking about front or rear driveshafts? rear Link to comment Share on other sites More sharing options...
sinkrun Posted May 8, 2015 Author Share Posted May 8, 2015 Headed to the PNP Friday there $21.00 there if I can find a good one. Anyone know what years would be the same, its A 2001 XJ? I have a lot of experience searching parts at pic-n-pulls, and you will find the rear driveshafts are bent when they move the vehicle into place with a forklift. Very good point never gave it A thought, thanks. Link to comment Share on other sites More sharing options...
Pete M Posted May 8, 2015 Share Posted May 8, 2015 sorry, I was thinking fronts. I know less about the XJ rear shafts other than the sealed t-case output came about in ~96. Link to comment Share on other sites More sharing options...
Incommando Posted May 8, 2015 Share Posted May 8, 2015 The yoke from my '91 2wd fit fine on the sealed t-case output I swapped in. The donor was a '98. Link to comment Share on other sites More sharing options...
sinkrun Posted May 9, 2015 Author Share Posted May 9, 2015 Headed to the PNP Friday there $21.00 there if I can find a good one. Anyone know what years would be the same, its A 2001 XJ? I have a lot of experience searching parts at pic-n-pulls, and you will find the rear driveshafts are bent when they move the vehicle into place with a forklift. Very good point never gave it A thought, thanks. Went today every shaft was bent or dented just as you said. Link to comment Share on other sites More sharing options...
