1J7FJ36L3LL245773
ComancheLover90
1990 Jeep Comanche (not sure if its a pioneer/eliminator/etc) 2WD/4WD
Straight 6, 4L, I think its the A904 trans, not sure on the transfercase, the rear and front axle, and the wheelbase (if anyone could tell/guess what mine could be, that'd be great)
Build date: 4/90
Current Location: Sacramento, CA. Current Status: Driveable
Nothing really special about it, other than missing an E, so its a jep. Exterior is blue, but fading fast. interior is grey, Bench seat, vinyl and fabric lined, Column shift,
I am current owner, and will always own.
here is a picture of it
If its a 90 auto then it has the AW4 rather than the A904
if you look at the fuel door you can tell if you have a short wheel base or a long wheel base.
If the fuel door is nearly touching the rear flare then its  a LWB if you have several inches between the fuel door and the rear flare then it is a SWB.
You can tell if it is 2wd or 4wd a few ways: the presence of a transfer case, the presence of a 4wd snifter, the presence of a front differential rather than beam axle.
If it is a 4wd then you will have a dana 30 front differential, if it is 2wd then you will have a dummy beam axle instead.
  • 4 years later...
*X1 TRIM STYLE X1 - CLOTH BENCH
-SA Charcoal
142 Zone 42-Detroit
1AA U.S. Dealer Retail
5KN Metro Cars of Detroit
ADL Skid Plate Group
ALN Body Color Bumper Group
APA Monotone Paint
ARL 300 Premium Group
BAY 105 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHN Command-Trac Part Time 4WD System
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K2X STRIPE/BADGE/MOLDING/COLOR
K3L STRIPE/BADGE/MOLDING/COLOR
KKE
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8
QB8 MIDNIGHT BLUE MET CC SEC PNT - HB8
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TMW P265/60r18 BSW A/S All Terrain Tires
WJD 15X7.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85
Right Front Spring Group XIV
Body Model JL61
Build Date 4/10/90
  • 1 year later...
