Jacob Ochs Posted April 29, 2015 Posted April 29, 2015 Here's a tool that I made to avoid the 20 mile trip to the parts store. I used the factory shaft bolt that holds the wheel on and a washer and 2 studs. I also don't weld that bad this was just a quick little project to get my ignition cylinder changed out. Hope I helped, I'm sure it can be made out of different materials as well.
schardein Posted April 30, 2015 Posted April 30, 2015 That's genius. I have the tool and carry it with me in my bag on junkyard outings. That would save some room and a little weight.
Incommando Posted May 13, 2015 Posted May 13, 2015 Jacob could you post up the washer and bolt specs for us?
shelbyluvv Posted May 23, 2015 Posted May 23, 2015 I think you could drill holes in the big washer, slide the bolts in the holes and then run some nuts onto the bolts.
Jacob Ochs Posted August 11, 2015 Author Posted August 11, 2015 Jacob could you post up the washer and bolt specs for us?Sorry I've been away from home but the washer was a 3/4 inch washer if I remember correctly and the two bolts were 1/2 inch cut down to an inch long and welded on each side
Jacob Ochs Posted August 11, 2015 Author Posted August 11, 2015 Does it even HAVE TO be welded?Yes or else the bolts would come flying out under the pressure
Jacob Ochs Posted August 11, 2015 Author Posted August 11, 2015 I think you could drill holes in the big washer, slide the bolts in the holes and then run some nuts onto the bolts.That's a good idea as well if you don't have access to a welder!
