WiscoXJ Posted April 30, 2015 Author Share Posted April 30, 2015 https://vimeo.com/126487550 Link to comment Share on other sites More sharing options...
neohic Posted April 30, 2015 Share Posted April 30, 2015 :cheers: Link to comment Share on other sites More sharing options...
WiscoXJ Posted April 30, 2015 Author Share Posted April 30, 2015 Here are some photos finally of what all is done so far. Need to bleed the brakes and install the shocks then test drive time. Brake lights aren't working but thatll be easy enough to figure out Link to comment Share on other sites More sharing options...
Zebvance Posted May 1, 2015 Share Posted May 1, 2015 are your motor mounts broke? The reason I ask Is because It looks like the engine is tweaked at a angle. Mine was like that to because my motor driver side mount was broke and the engine settled back and to the right some. Link to comment Share on other sites More sharing options...
WiscoXJ Posted May 1, 2015 Author Share Posted May 1, 2015 are your motor mounts broke? The reason I ask Is because It looks like the engine is tweaked at a angle. Mine was like that to because my motor driver side mount was broke and the engine settled back and to the right some. they are fairly worn. Once its running and driving how I want it I'm going to get the brown dog ones. Link to comment Share on other sites More sharing options...
WiscoXJ Posted May 8, 2015 Author Share Posted May 8, 2015 figured id give an update. truck is almost done. drove it for the first time ever last night. I have no head lights or dash lights so that's cool Link to comment Share on other sites More sharing options...
rustybottoms88 Posted May 10, 2015 Share Posted May 10, 2015 You might think about just driving it during the day until you get headlights. Lol Link to comment Share on other sites More sharing options...
WiscoXJ Posted May 10, 2015 Author Share Posted May 10, 2015 Lol I know that's kinda where I'm at Link to comment Share on other sites More sharing options...
WiscoXJ Posted May 12, 2015 Author Share Posted May 12, 2015 Took the truck for a few little spins today. But going from park to drive it dies, same if your on an incline in drive it will die. If u keep the rpms a little higher and go to drive it won't die. Idle air valve? Any ideas? Link to comment Share on other sites More sharing options...
buxmj Posted May 13, 2015 Share Posted May 13, 2015 Maybe a vacuum leak? Link to comment Share on other sites More sharing options...
WiscoXJ Posted May 13, 2015 Author Share Posted May 13, 2015 Seems a little harsh for a vac leak. Plus I just plumbed everything. I'll double check tho Link to comment Share on other sites More sharing options...
rustybottoms88 Posted May 14, 2015 Share Posted May 14, 2015 How is the idle when in park? Does it idle in gear after it is coaxed into the initial gear engagement? Link to comment Share on other sites More sharing options...
WiscoXJ Posted June 2, 2015 Author Share Posted June 2, 2015 ya it did. Ended up neing the idle air valve. after that was fixed I took it down the road and I was getting a loud grinding. ended up being the tcase. I don't know how the tcase goes bad by taking it out of one truck and putting it in other but I got a new one for free so whatever. trying to find time now to put it back in and test everything out. then I need to find out why my low beams don't work as well as my hi blower setting. then I need to get my a/c working Link to comment Share on other sites More sharing options...
WiscoXJ Posted June 5, 2015 Author Share Posted June 5, 2015 Typical night with the mj.. Attempt a step forward. Take ten backwards. New tcase was 23 spline like I needed but had a lip inside the input that wouldn't let it slid in all the way which led to me learning how to swap inputs on the fly. Oh so fun. Link to comment Share on other sites More sharing options...
rustybottoms88 Posted June 5, 2015 Share Posted June 5, 2015 Tough love from the MJ. How did the chain look? Link to comment Share on other sites More sharing options...
WiscoXJ Posted June 5, 2015 Author Share Posted June 5, 2015 in the original tcase everything looked like hell. I couldn't hardly get the synchros to match up by hand. in the other one everything looked almost new. the magnet had barely any debris on it Link to comment Share on other sites More sharing options...
Crash Posted June 5, 2015 Share Posted June 5, 2015 If you're gonna make an omelette, you gotta break some eggs. Link to comment Share on other sites More sharing options...
WiscoXJ Posted June 8, 2015 Author Share Posted June 8, 2015 ^ :yes: Link to comment Share on other sites More sharing options...
Kickinmule Posted June 9, 2015 Share Posted June 9, 2015 If you're gonna make an omelette, you gotta break some eggs. My omelette usually turns into scrambled eggs that the dog gets to eat... Link to comment Share on other sites More sharing options...
WiscoXJ Posted June 19, 2015 Author Share Posted June 19, 2015 TRUCK IS COMING HOME TOMORROW Link to comment Share on other sites More sharing options...
rustybottoms88 Posted June 19, 2015 Share Posted June 19, 2015 Where has it been? Link to comment Share on other sites More sharing options...
sang_route Posted June 20, 2015 Share Posted June 20, 2015 if your that far might as well get a 231C outa an s10 and swap over the heaver duty internals great build btw, never surender :wrench: Link to comment Share on other sites More sharing options...
WiscoXJ Posted June 23, 2015 Author Share Posted June 23, 2015 Where has it been? It was at a buddies shop due to me living in an apartment complex Link to comment Share on other sites More sharing options...
WiscoXJ Posted June 23, 2015 Author Share Posted June 23, 2015 Finally got its shoes on Link to comment Share on other sites More sharing options...
rustybottoms88 Posted June 26, 2015 Share Posted June 26, 2015 Finally got its shoes on I like the shoes and the topper. Do you work at a VW dealership? Link to comment Share on other sites More sharing options...
