Jeep Driver Posted December 11, 2014 Share Posted December 11, 2014 http://www.metalcloak.com/TJ-LJ-Jeep-Wrangler-Solid-Chromoly-Front-Track-Bar-p/7035.htm Looking at this track bar, any of you deal with these guys? have their track bar? Thanks Link to comment Share on other sites More sharing options...
Timeless Posted December 11, 2014 Share Posted December 11, 2014 I do not, but I don't see the value in it. There are plenty of other options out there for better prices. Link to comment Share on other sites More sharing options...
A-man930 Posted December 11, 2014 Share Posted December 11, 2014 I stay away from heim joints for street driven rigs. No protection from the elements so they wear out quickly. Just my $.02 I have an adjustable one from JKS (has a re-buildable johnny joint) and I couldn't be happier. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 11, 2014 Share Posted December 11, 2014 10-4 all the above. But the gold color gives it a slight bling factor. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 11, 2014 Author Share Posted December 11, 2014 Not about the bling. I'm looking for a double shear TB for 0 lift. I spoke to Andy yesterday at Ironman to see if he would make me one. Apparently I'm not the only one with this request but no one has been able to successfully design one. I do not what a lift. I DO what better handling and installing a lift just to get a double-shear would defeat the purpose. I'm on my 5th TB in 2.5 years, I'm done with this $#!&. Andy said he'll take another look at designing one and get back with me next week. Part of the problem with his design is that the adjustment for length is at the frame mount end rather than the axle end, so clearing the dif is problematic. Raising the pivot point at the frame end will require me to raise the pivot point at the axle end......that I can handle myself and will probably be discussed with my next call to him. Any ideas? Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 11, 2014 Author Share Posted December 11, 2014 http://jksmfg.com/i-13306791-cherokee-xj-comanche-mj-1984-2001-adjustable-front-trackbar-fits-1-3-5-lift.html Any thoughts on this one? Link to comment Share on other sites More sharing options...
MuddFoot Posted December 11, 2014 Share Posted December 11, 2014 http://www.metalcloak.com/TJ-LJ-Wrangler-Coils-Dual-Rate-3-5-Front-p/7060.htm these look nice. do you think they would make any difference?? whats wrong with a good stock replacement for your tb goto napa. i seen a 0-3 tb but i think its rc. Link to comment Share on other sites More sharing options...
MuddFoot Posted December 11, 2014 Share Posted December 11, 2014 http://www.ebay.com/itm/Jeep-Wrangler-TJ-Cherokee-XJ-Grand-ZJ-Heavy-Duty-Adjustable-Front-Track-Bar-/251428481107 says 0-5in Link to comment Share on other sites More sharing options...
dasbulliwagen Posted December 11, 2014 Share Posted December 11, 2014 I got a new pro comp adjustable track bar for free and installed it on my MJ. It has a heim at the body aide with the adjuster there. Screwed all the way in is just about right on my truck that has 4wd springs and an extra isolator. I see they go for $200 and says its good up to 4 inches lift. I've had no issues with mine installed for several years now. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 11, 2014 Author Share Posted December 11, 2014 On 12/11/2014 at 9:34 PM, dasbulliwagen said: I got a new pro comp adjustable track bar for free and installed it on my MJ. It has a heim at the body aide with the adjuster there. Screwed all the way in is just about right on my truck that has 4wd springs and an extra isolator. I see they go for $200 and says its good up to 4 inches lift. I've had no issues with mine installed for several years now. Is yours a daily driver? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted December 12, 2014 Share Posted December 12, 2014 On 12/11/2014 at 11:15 PM, Jeep Driver said: On 12/11/2014 at 9:34 PM, dasbulliwagen said: I got a new pro comp adjustable track bar for free and installed it on my MJ. It has a heim at the body aide with the adjuster there. Screwed all the way in is just about right on my truck that has 4wd springs and an extra isolator. I see they go for $200 and says its good up to 4 inches lift. I've had no issues with mine installed for several years now. Is yours a daily driver? Yes mine is a semi daily driver. Link to comment Share on other sites More sharing options...
xjrev10 Posted December 12, 2014 Share Posted December 12, 2014 IRO is the way I go. I've bought and installed at least a half dozen of these in the last few years... Awesome product. http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=10215&Category_Code=XSP Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 12, 2014 Author Share Posted December 12, 2014 On 12/12/2014 at 4:38 AM, xjrev10 said: IRO is the way I go. I've bought and installed at least a half dozen of these in the last few years... Awesome product. http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=10215&Category_Code=XSP On stock trucks with NO lift? Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 13, 2014 Author Share Posted December 13, 2014 What I figured out- When you order a TB from rockauto or the auto parts stores they list the TB for '84-'01 XJs. You will see here- http://www.quadratec.com/products/56013_01.htm they list separate TBs for '84-'90 and '91-'01. I'm wondering if the taper has changed at '91 and if the parts supplies are selling the '91+ as a fit for all years? I went yesterday to the PnP and got a good clean chassis mount off a '98 and installed one of my old TBs on my truck....no movement. I'm left to conclude that the newer TBs have worn out my old mount as the tapers do not match. Link to comment Share on other sites More sharing options...
MuddFoot Posted December 14, 2014 Share Posted December 14, 2014 could be or maybe someone didn't tighten the nut up and it messed up your mount Link to comment Share on other sites More sharing options...
shelbyluvv Posted December 15, 2014 Share Posted December 15, 2014 My 86 has a different TB mount than the one that I put on it from a 94 XJ. The hole was smaller in the 86's TB mount. I couldn't get my castle nut seated far enough to put the cotter pin in. Switched to the later one and problem solved. Link to comment Share on other sites More sharing options...
xjrev10 Posted December 15, 2014 Share Posted December 15, 2014 On 12/12/2014 at 8:41 AM, Jeep Driver said: On 12/12/2014 at 4:38 AM, xjrev10 said: IRO is the way I go. I've bought and installed at least a half dozen of these in the last few years... Awesome product.http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_Code=10215&Category_Code=XSP On stock trucks with NO lift? Why not? Link to comment Share on other sites More sharing options...
