1991 Comanche 4x4
flufrooster
This is a 1991 with a 1988 4.0 in it.  Automatic 4x4.  The motor had been swapped before I bought it.  All the HO stuff was taken off the old motor and put on the 88.  I have not been able to get it to start.  It will crank, has fuel and spark but not continuously.  I have replaced the dizzy, dizzy cap and rotor, plug wires, crank sensor, and computer.  I'm tired of working on it, so it has to go.  The body is in pretty good shape.  It has a dent by the drivers door, on the outside post.  No rust.  $900 obo
I also have the 88 Cherokee that the motor came out of that I will include.  It was put in a ditch, so the right front is messed up.  The axles are good, and it has a nice 3" lift on it.
It would be nice if your , and the Jeeps, location were known. Might make it easier for someone to decide if they're interested or not.
This is a 1991 with a 1988 4.0 in it.  Automatic 4x4.  The motor had been swapped before I bought it.  All the HO stuff was taken off the old motor and put on the 88...
By chance, was the flex plate from the HO swapped to the '88 engine too?
SW86 it is red.  I have some pics, but I can't get them or my craigslist link to load.  If you go to craigslist Nashville it listed there as 1991 Jeep Comanche.  Or you can message me and I will text them to you.  Thanks
Archived
