zj dash
Don't think it's feasible to do so... Aside from the mechanical fabrication, you'd likely have to swap over the entire dash harness, which would not be readily compatible with the MJ harnesses, ECU and TCM.  Even if you had a manual transmission, you'd probably get a CEL if you could adapt the electronics.
There was pictures of a gray MJ floating around years that had a V8 swap with a ZJ donor and the guy swapped the whole dash over. Everything seemed to fit with trimming but if I remember right there looked like there was just about zero leg room under the dash. Can't find it right now, but I know it's out there...  :hmm:
I have seen it too.
I think it's was a for sale ad.
