comanchebuilder21 Posted September 20, 2014 Posted September 20, 2014 I have a short bed with 5.5inch lift on 38s atm I have a drives haft from a long bed I know the splines match but will the length fit?
mvusse Posted September 20, 2014 Posted September 20, 2014 Not even close. Long bed driveshaft is 7" longer than short bed one. It will probably be about 5" too long.
comanchebuilder21 Posted September 20, 2014 Author Posted September 20, 2014 So will adding more lift work
Eagle Posted September 20, 2014 Posted September 20, 2014 So will adding more lift work Yeah -- if you add about three feet of lift.
comanchebuilder21 Posted September 20, 2014 Author Posted September 20, 2014 Hmm that's to much lift on a comanche. Atleast for me
Incommando Posted September 21, 2014 Posted September 21, 2014 I have a short bed with 5.5inch lift on 38s atm I have a drives haft from a long bed I know the splines match but will the length fit? Soooo...if you have the truck and the shaft removing 4 8mm bolts would allow you to test fit the shaft....
comanchebuilder21 Posted September 22, 2014 Author Posted September 22, 2014 Going to once I put Trans back in just wanted to see if anyone's tried it or knew
