Jeep Driver Posted September 1, 2014 Share Posted September 1, 2014 I want to use this style intake- I have this style now- And I need to adapt my PS bracket to the MPI intake. Thanks. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 2, 2014 Author Share Posted September 2, 2014 None of you guys have an early Chrysler version of the 2.5? Link to comment Share on other sites More sharing options...
88whitemanche Posted September 2, 2014 Share Posted September 2, 2014 Idk if this help or pm him for more pics of the bracket.....mnkyboys is doing a similar swap http://comancheclub.com/topic/16226-mnkyboys-89-comanche-project/page-17 Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 2, 2014 Share Posted September 2, 2014 There is a 91 2.5 mj at the local JY . I can go take a pic tommorow provided it doesn't rain like it's forecasted . They have a minimum of $25 bucks if youre interested in having me pull it and ship it to you. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 2, 2014 Author Share Posted September 2, 2014 There is a 91 2.5 mj at the local JY . I can go take a pic tommorow provided it doesn't rain like it's forecasted . They have a minimum of $25 bucks if youre interested in having me pull it and ship it to you. Thank you but I won't ask anyone to go out of their way. I'm planning ahead. I need to order the 91-95 intake and I want to make certain that the PS pump is also the belt tensioner. The late model intake has the PS pump fixed and uses an idler pulley as a tensioner. My main concern is that the pulley lines up with the balance of the 88 accessories. I'm really looking for info more than anything, that said, if anyone has one I'll be happy to buy it. I need to get the 91-95 intake and plug/braze the injector holes as this will be used with TBI. Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 2, 2014 Author Share Posted September 2, 2014 If anyone is wondering why I'm going for the MPI intake with TBI....>? $#!&loads of torque. Link to comment Share on other sites More sharing options...
mnkyboy Posted September 2, 2014 Share Posted September 2, 2014 My brackets have different number cast in them but look identical,everything is pulled back a little with the MPI setup but I think as far as the PS pump the difference is in pully depth. I used a 95 PS bracket but only because I had one, it looks like the TBI bracket would work. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 2, 2014 Share Posted September 2, 2014 I don't make an offer to go to the JY and say what a hassle it was , I offered lol. That being said , why don't you put the injectors in the newer intake and really screw with people ? They won't know if it's TBI or MPI . If you want me to check on a price for the intake I can . Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 2, 2014 Author Share Posted September 2, 2014 I don't make an offer to go to the JY and say what a hassle it was , I offered lol. That being said , why don't you put the injectors in the newer intake and really screw with people ? They won't know if it's TBI or MPI . If you want me to check on a price for the intake I can . Thanks, if you go that way and you want to stop anyway......LMK........thanks again. Where the fuel rail is now.......using the mounts on the intake.......I plan on making up a steel pipe heater line and route what is now the line that heats the 88 intake. I also need to make up a fitting for the ECU temp sensor at the end of it where it will connect to the heater hose that runs to the valve. The late 2.5...as with the 4.0... has the heater line running on the distributor side of the engine and the ECU temp sender is on the stat housing, my Efan switch is in the stat housing and I want to leave it there. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 2, 2014 Share Posted September 2, 2014 As of right now it's not raining . Pm me your number . I'll take some picks, get a price and can pull and ship it to if needed . Link to comment Share on other sites More sharing options...
Comanchemodder Posted September 2, 2014 Share Posted September 2, 2014 Not knowing any better, I just used the 1994 YJ 2.5 PS pump/bracket and bolted it to my RENIX intake. Not until you posted the question, did I wonder if they are different. For me, they look/function the same. That being said, I remember the offset was slightly different (due to oil slinger?). Link to comment Share on other sites More sharing options...
