introduction and important question (long bed owners!!!)
hey long bed owners!  (and everyone else)  glad to be here.  XJ owner, but buying more MJ parts...  I have an important question to ask you.
what is the measurement, in inches, from the front of a long bed to the center of the wheel opening?
i'm having a custom frame made to put a long bed on to tow behind my XJ, but the bed is over an hour away, and i know someone on this board has an encyclopedic brain ;)
thanks!
I found the shortbed frame blueprint. It shows the forward and rear spring eye locations, so just add the difference between the SWB and LWB to the dimensions ahead of the forward spring eye and you've got it.
Image Not Found
A number of years ago, I measured and wrote down the inside dimensions from the front wall of the bed to the rear edge of the bed floor for a mat ...88½";  from front inside wall to front of wheel well.... 27";   from rear of wheel well to rear edge of bed floor .... 27";   which puts center of wheelwell 44¼" from inside front wall of the bed. Wheel wells are centered on the bed on the long bed.
