Just Us 2.5 Guys, Inspired By Bobby54
Bobby, with his vacuum troubles, got me energized to get started with mine.
Shorty after I got the truck I found an AMC plastic cover at the PnP and installed it. The Ultra Black RVT was no match for a plastic cover.
Image Not Found
I found this at the PnP off a 91 Wrangler, cleaned up real nice.
Image Not Found
After 60K miles, she's still clean inside.
Image Not Found
I used brake line to make up new vacuum line.
Image Not Found
And a new molded hose on the breather side to the plenum.
Image Not Found
Next will be eliminating the EGR........to be continued.
Image Not Found
Wow! That's how my plastic cover was crumbling to....if anyone else does this upgrade...it's better to use the molded rubber valve cover gasket from a 1998 Dodge Dakota with the 2.5 4cyl....
Part # vs50502r.... About $20
I did get a rubber gasket. My VC has lugs that the rubber did not go around. I went to the Dodge dealer yesterday and there was no gasket for it, note on parts list stated RTV only.
I just upgraded mine to a 95 wrangler cover, now I don't have to worry about blowing my fill cap off while I'm out smoking 4.0ls.
:rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf: :rotf:
love it haha.
I'm in the look out for these aluminum covers you all speak of
