thejum57 Posted May 11, 2014 Share Posted May 11, 2014 Hey guys, thanks for all the help in "the pub" about posting from photo bucket, but still no luck. So I will wing it. My truck starts ok, but after a little bit of driving, the engine begins to race! I get to a stop sign push in the clutch and it revs like crazy! The throttle cable really doesn't seem to be sticking. There is this electronic device thing with a tiny plunger that the cable "rests" on when you let off the gas peddle. The plunger thing seems to move freely also. Any ideas on what I can do...or the name of this device in case I need to replace it? Thanks, Jim Link to comment Share on other sites More sharing options...
Eagle Posted May 11, 2014 Share Posted May 11, 2014 What year? What engine? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 11, 2014 Share Posted May 11, 2014 What year? What engine? Signature says 86 Comanche 2WD 5spd 2.5liter. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 12, 2014 Share Posted May 12, 2014 When it happens, is the plunger sticking out and holding the throttle linkage open? Link to comment Share on other sites More sharing options...
88whitemanche Posted May 12, 2014 Share Posted May 12, 2014 This? Link to comment Share on other sites More sharing options...
cruiser54 Posted May 12, 2014 Share Posted May 12, 2014 Yes. That's the Idle Speed Controller aka ISC motor. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 12, 2014 Share Posted May 12, 2014 Mine does not work, has not worked since I owned the truck. You can make it go away.......assuming yours runs well.......not necessary in my opinion. Even with AC on, mine does not bog. There is also an idle control switch on your PS pump pressure line that may be activating it. Simply unplug the two and see what happens. Link to comment Share on other sites More sharing options...
thejum57 Posted May 12, 2014 Author Share Posted May 12, 2014 Yes, that is exactly what I'm talking about. I am finally able to move the pics but no need now, thanks! I will try the suggestions and see what happens, thanks again. Link to comment Share on other sites More sharing options...
