Strokermjcomanche Posted April 26, 2014 Share Posted April 26, 2014 Has anyone used this Lizard skin ?? It's a spray on sound deadener that is supposed to be a water barrier also . I was thinking on using it on the floors of my truck instead of the jute padding A.K.A "sponge" . I would like to hear from someone that's used it and had it in there truck / car for an extended period of time to see how it holds up . Thanks in advance . Link to comment Share on other sites More sharing options...
Dillithium Posted April 26, 2014 Share Posted April 26, 2014 Sound pressure reducing can be done in a few ways, but I can't imagine a spray on system will work very well. Most of the time you need ''thickness'' for the best effect. Have you considered something like Dynamat? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 26, 2014 Author Share Posted April 26, 2014 Although its nice to be quiet It's not as important to me to have the sound deadening quality as it is the water barrier . I've seen dynamat , but it's more expensive and time consuming IMO . Link to comment Share on other sites More sharing options...
johnj92131 Posted April 27, 2014 Share Posted April 27, 2014 Worried about water in the cab or water outside the cab? I presume water = rust is the concern. If so, then Pour 15 on the inside floor and walls should be the solution, no? Link to comment Share on other sites More sharing options...
Akula69 Posted April 27, 2014 Share Posted April 27, 2014 We used a sound deadener / heat shield from here: http://www.lobucrod.com And it works great! Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 27, 2014 Author Share Posted April 27, 2014 I used por 15 on my s-10 blazer and wasn't pleased with the results . But yes water= rust. I figured a sound deadener / water barrier on the inside of the floors would kill two birds with one stone . If I used por 15 then Id have to find something to deaden sound . Akula : how long has it been in ? Have you taken a look to see how it's held up? Thanks Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 27, 2014 Author Share Posted April 27, 2014 Has anyone used lizard skin?? Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 27, 2014 Share Posted April 27, 2014 Has anyone used lizard skin?? No. But I would. Spray on insulation is the way of future. Virtually every home I work on now has it. Thicker is not more...... I just looked at this stuff......looks good......but is not a substitute for carpet pad/backing. Also, it's a waterborne product, make certain your metal is clean.......clean........clean........or use a solvent based metal primer first. Link to comment Share on other sites More sharing options...
reece146 Posted April 27, 2014 Share Posted April 27, 2014 Research home made lizard skin: microspheres in house paint. Works like "the real thing" at 1/5 the cost. I haven't used it personally but will soon. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 27, 2014 Author Share Posted April 27, 2014 Thanks Jeep Driver . I plan on putting carpet in on top of the lizard skin . I'll have to live without the jute padding . When I took the old carpet and padding out it was so waterlogged . Atleast when the carpet gets wet in the winter from the snow it'll dry quicker than the padding . I just was wondering how it holds up Link to comment Share on other sites More sharing options...
88Pghcomanche Posted April 27, 2014 Share Posted April 27, 2014 I used a paint on sound deadener (cheaper variant of lizard skin) on the inside of my cab and firewall. Its been on for 2 yrs without a problem. I painted it on top of Por-15 (2 coats). But my MJ lives in the garage, only coming out for sunday drives and trips to the hardware store. http://comancheclub.com/topic/33233-88-build/ Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 27, 2014 Author Share Posted April 27, 2014 Thanks Pghcomanche that's exactly what I was looking to do to my truck . Are you going to bantams jeep festival in butler fathers day weekend? Link to comment Share on other sites More sharing options...
88Pghcomanche Posted April 27, 2014 Share Posted April 27, 2014 Thanks Pghcomanche that's exactly what I was looking to do to my truck . Are you going to bantams jeep festival in butler fathers day weekend? No problem. I didn't even think about taking the MJ to a jeep festival. I'll try to make it up there this year. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 27, 2014 Author Share Posted April 27, 2014 I'm in Youngstown . My trucks going to be the one in the museum and I'm going to bring my dd mj also . It would be nice to have more Mjs there . Look me up if you end up going . . Link to comment Share on other sites More sharing options...
88Pghcomanche Posted April 27, 2014 Share Posted April 27, 2014 I just googled bantam jeep festival. Looks like a good time. I'll send you a PM in june. MJ's and old FC are rarely seen around hear, would be nice to see more. Thanks for the heads-up on bantam jeep festival. Link to comment Share on other sites More sharing options...
Comanchemodder Posted April 28, 2014 Share Posted April 28, 2014 Trucks! episode 2010-17 used it on their project superdually: http://www.powerblocktv.com/episodes/TK2010-17/super-dually-part-5-sound-insulation-bedliner-installation Link to comment Share on other sites More sharing options...
