d44 axle flang
D44 front?
No.
D44 rear.... Yeah. But it's hard. You have to turn down the centre 'hub' portion of the flange, and then there may or may not be enough clearance on the back side for stud installation.
The problem is the 5x4.5 pattern is bloody small.
I had a discussion recently with a potential buyer of one of my 8.8s and he wanted to do the same thing, but after I gave him the flange diameter he said the explorer flange is just not wide enough. :(
make spacers that go from 5 to 6 lug. all you need is a round steel plate that's the thickness spacer you need, and drill out the center so that it sits flat, and then drill the holes where you need them.
any machine shop could do it and probably fairly cheap
Change the front hubs to ford f150 style... 5x51/2, and you can get 8.8 shafts in that bolt pattern, or get spacers that go from 4.5 to 5.5. I know spider trax makes them. Look into yukon 8.8 shatfs, I know they make custom 35 spline 60 shafts you have to cut down for less then 80 bucks a side
