88swampedmj Posted April 24, 2007 Posted April 24, 2007 will a tj rubicon 4.10 R&P fit in my waggy 44?
Oizarod115 Posted April 24, 2007 Posted April 24, 2007 if they are both LP i think it should be alright, check the parts numbers at some gear places online.
DirtyComanche Posted April 24, 2007 Posted April 24, 2007 Don't quote me. But it should fit providing you use a high ratio carrier.
88swampedmj Posted April 25, 2007 Author Posted April 25, 2007 well it comes with the carrier, for only 45 i could get the R&P and carrier so i was hoping it would work in my 44 but idk if ill do it, i want 5.13s so i may just wait but id like to get those 4.10s so i can hurry up and put the 44 under the truck
88MJay Posted April 25, 2007 Posted April 25, 2007 I'm thinking they are different for some reason. Thicker gears maybe? You may want to make a phone call on that one. Of course I could be wrong again. Wouldn't be the first or last time. :roll:
88MJay Posted April 25, 2007 Posted April 25, 2007 Yukon says this about Rubicon gears... "Product Description The Jeep Wrangler Rubicon uses a special set of Dana 44 axles. These gears will fit the stock lockers. This ring and pinion set will fit the front or rear of a Rubicon." They are a different part number than regular D44 gears. Doesn't diffinatively answer your question though.
JOMJ87 Posted April 25, 2007 Posted April 25, 2007 They should fit but they are thick gears instead of normal. Also the bolts in the ring gear are different size. I think they go up to 7/16th or higher i just can't remember off the top of my head. Cole
holeski Posted April 28, 2007 Posted April 28, 2007 No they are not the same. The rubi 44 are not true Dana 44 housings. If you need gears PM me and we might be able help you out with a good price.
88swampedmj Posted April 28, 2007 Author Posted April 28, 2007 well i just realized they are not rubicon 4.10s they are just 4.10s for a tj with a rear 44
