44 gear question
well it comes with the carrier, for only 45 i could get the R&P and carrier so i was hoping it would work in my 44 but idk if ill do it, i want 5.13s so i may just wait but id like to get those 4.10s so i can hurry up and put the 44 under the truck
Yukon says this about Rubicon gears...
"Product Description
The Jeep Wrangler Rubicon uses a special set of Dana 44 axles. These gears will fit the stock lockers. This ring and pinion set will fit the front or rear of a Rubicon."
They are a different part number than regular D44 gears.
Doesn't diffinatively answer your question though.
They should fit but they are thick gears instead of normal. Also the bolts in the ring gear are different size. I think they go up to 7/16th or higher i just can't remember off the top of my head.
Cole
