Hillcountrymac Posted February 11, 2014 Share Posted February 11, 2014 Hello everyone.I just bought a 1990 in great shape.I am missing the jack and have a couple of questions.First : is it the same as a Cherokee? Second:could someone take a picture of it mounted behind the seat so I can use it as a reference?Also I've read the hints(thanks) and will follow the advice.Looks like a great forum and I look forward to the addiction and all that goes with it. Link to comment Share on other sites More sharing options...
jpdriver1 Posted February 12, 2014 Share Posted February 12, 2014 welcome to the pool Link to comment Share on other sites More sharing options...
cruiser54 Posted February 12, 2014 Share Posted February 12, 2014 Welcome. I can take a photo of my jack/handle etc for ya if ya want. Link to comment Share on other sites More sharing options...
Eagle Posted February 12, 2014 Share Posted February 12, 2014 And it is the same as a Cherokee. Link to comment Share on other sites More sharing options...
danbyrambler Posted February 12, 2014 Share Posted February 12, 2014 Greetings - You're gonna like it here - lotsa help - - Here's a jack pic & jack instruction pic: http://comancheclub.com/topic/14760-jack-and-rod/#p157554 http://comancheclub.com/topic/23981-stock-jack-configuration-diagram-pic/ Search is a good tool - - Search using Google for CC info is better/easier - Enter SITE:COMANCHECLUB.COM & then whatever - fast & easy :thumbsup: Link to comment Share on other sites More sharing options...
gogmorgo Posted February 12, 2014 Share Posted February 12, 2014 I've got the jack, except it's seized... and as a result about 400 miles away. It does, however, go under the axle tubes, which are the same on the MJ as the XJ. Don't really see them using a different jack between the Cherokee and Comanche when they don't really need to. But I might have a better replacement option for you than an XJ screw jack. As to how it mounts, there's an elastic strap with a couple d-rings that go into hooks in the rear wall of the cab, behind the driver's seat. I've got an ancient little hydraulic bottle jack that I had mounted in that spot until I decided I needed more room behind the seats for storage. Now it lays on the floor under the passenger seat. There's also a spot for the factory jack handle and tire iron, bit of a cloth hold-down strap they slide into IIRC. I replaced the stripped tire iron with a ratcheting breaker bar and 3/4 deep socket. The handle for the bottle jack is long gone, so I just pump it with the breaker bar handle. I pulled all my emergency equipment out from behind the seats, so when I get around to putting it back it wouldn't be too big a deal to snap a pic or two of it in the factory spot. That is, the non-factory jacking stuff I've got in the locations for the factory stuff. Link to comment Share on other sites More sharing options...
Hillcountrymac Posted February 12, 2014 Author Share Posted February 12, 2014 Thanks everyone.I found the folding handle and I think I'll go with the bottle jack , breaker bar and socket. Link to comment Share on other sites More sharing options...
