Back Of Cab, Light?
Your truck should have two lights - one on each side just above the upper anchor point of the lap/seat belt.  Most of the time, they don't work after 20 years.  But that is where they should be.  The lights tilt to turn off and on.  they also work when the door is open - depending on the tilt position.
See this post for a picture:  http://comancheclub.com/topic/41811-b-pillar-lights/
my '88 jeep has no cab light above the back window.
any kits out there to add one? or is there select trucks I can pull a light off of at the junk yard?
Thanks
Thanks
I installed 1"x6" led flood light bought of eBay works a lot better than my dads stock one lights the bed very good picked it up for 30$ with free shipping several ways you can wire it in I just used a toggle
Is the OP asking about a cargo light for the box or a light for the cab interior above the back window?  "Cab light" term caused me to think of the interior of the cab.  Not the Exterior light for the box.  If he is asking about a cargo box light, I noticed a truck at the Pick N Pull with a combined high 3rd brake lite and cargo box light just last week.  Foolishly did not look closer at it.
Yea, I was asking about the 3rd brake light / bed light.
I'm looking for a semi-stock part. Not a factory part, just needs to look like something factory would use.
On the inside lights, I already bought new replacements, found em on Amazon.
ggcnash, you have a picture of that light?
Thanks for your answers
I added a 12V work light to my roll bar and wired it in such a way that it is on a separate harness that is hooked into the factory switch for trigger power to the relay --- the light is upside down and pointed to the middle of the bed
