Heater Core Valve Hub Delete - 2.5
if i were to do that wouldnt there be a constant flow through the bottle? if so why couldn't i run hose from t-stat to lower core inlet then hose from upper core outlet to w-pump. it would be a full circuit.
so whats the bottle for? reserve fluid or an overflow?
srry for asking many questions btw just like to certain before i go and do anything
  • Replies 60
ok ok i thought about it, if i were to do it that way with my bottle it will eliminate that valve and if i were to over heat or what not it would piss out the bottle cap and not blow a hose off or worse. correct?
Just my 2 cents......why don't you toss in a rad with a cap..and a reservoir (JY Cherokee??)....toss out the pressure bottle on the fire wall and the heater bypass valve...and your good to go with no problems. :dunno:
what i don't like is how does the coolant flow know when to flow through the core or the jug with them tee in there. like rockfrog said if i didnt put the tee in and just connected the upper jug hose direct to t-stat then lower hose to core and core to pump it would make a full circuit. i like that idea cause in this pic the coolant could still bypass the core go through the jug and to the pump.
There already is constant flow through the bottle. The valve is there to redirect it through the heater core when you turn on the heat. Otherwise coolant flows though the bottle ... it's a closed loop cooling system. It's not like the usual open loop system that runs an overflow bottle.
to help visualize if i were to take all this cluster out and by new hoses could i run the *to t-stat* hose directly into the *upper hose* on the jug, connect *lower hose* into the core. then back to w-pump. so there would be no Tee's
exactly so why did they use the tee's when u can just do what u said and make the circuit going through the jug
see post#31
Thats ecactly what I was trying to say earlier
i know, i know, srry. i understood how u wanted me to route the system i just didnt understand why i couldn't run it directly through the core, is it bec. the bottle will release pressure through the cap if it were to overheat and not blow a hose off or something.
In 41, drilling a small hole in the thermostat will allow some air to pass through. On one of my more resent threads it was mentioned. There are some that have a little valve that does the same thing, but I could not get one from my parts store with that feature. So I went the small hole route.
You will still need to bleed the air out of the system however.
  On 1/18/2014 at 5:55 AM, Rockfrog said:
It goes like this (on a 4.0L but the heater plumbing is the same). I used all 5/8" hose here ... fits fine one circuit, bit tight but doable on the other.
And no, the heat is not on all the time ... just saying
Sorry to bring this up again, but i don't know if anyone answered this: how come i can't just run the hoses direct to the core like above, without running a return bottle?
Because your coolant expands at temperature. Without the bottle it will just go out to the ground. It could be done but you have to figure out the amount of expansion and under fill accordingly. That's how it was done decades ago. Just have to check coolant regularly.
Its just not kosher to dump coolant into the environment.
I originally modified a fast orange hand cleaner bottle at first ... sqeezed it in beside the air cleaner box.
oh duh, thanks for the input i guess ill stick with what was mentioned earlier in this thread and run through my OEM jug. and to properly fill my system after this mod, would i fill the rad. and my jug or leave jug empty for the expansion?
Have some more pics, Blaine. Maybe this'll help shine some light on routing things. This is what I'll be doing to my '88 if it doesn't sell soon since I can drive it anyways until I replace coolant hoses, only I plan on grabbing a factory 91+ coolant bottle from a JY.
http://comancheclub.com/topic/24848-open-system/?p=259597
http://comancheclub.com/topic/27068-closed-to-open-cooling-system/?p=278686
well i know how i want to route it, pretty much was explained earlier, but how would i go about filling the system.
my plan is to run t-stat hose to upper inlet on my bottle, run hose from lower outlet of bottle to heater core, and the core back to w-pump.
so with this mod would i just fill the radiator, or do i fill the bottle as well?
