reubj Posted January 5, 2014 Share Posted January 5, 2014 I would like to replace the small stock side mirrors on my 89 MJ Pioneer with the larger door mount mirrors that were available as a factory option. Unable to find factory mirrors I found these that look somewhat close: http://www.amazon.com/CIPA-41100-Universal-Replacement-Mirror/dp/B00029WSXQ/ref=sr_1_1?ie=UTF8&qid=1388886533&sr=8-1&keywords=cipa+41100#productDetails Has anyone tried these? I beleve I will need to fab interior mounting plates to stiffen the door skin where the mirrors are mounted. Thanks for any help. Link to comment Share on other sites More sharing options...
87MJTIM Posted January 5, 2014 Share Posted January 5, 2014 If your doors were not originally with the "sport" mirrors, then they may not have the internal bracing for those mirrors. There is an internal metal brace that runs top to botton inside the door. This is to provide additional support from wind against the mirror. You could install those mirrors, but over time, the sheet metal may fatigue and bend. Link to comment Share on other sites More sharing options...
jimoshel Posted January 5, 2014 Share Posted January 5, 2014 I have found a couple doors where the factory had installed the stiffeners but not the mirrors. No way to tell without removing the door panel. Link to comment Share on other sites More sharing options...
reubj Posted January 5, 2014 Author Share Posted January 5, 2014 Thanks. I will check the interior of the doors. If there is no stiffener I'll whip something up. Link to comment Share on other sites More sharing options...
Kkilmer87 Posted January 5, 2014 Share Posted January 5, 2014 I have stock mirrors on doors just like tha Link to comment Share on other sites More sharing options...
Kkilmer87 Posted January 5, 2014 Share Posted January 5, 2014 For sale pm me for details Link to comment Share on other sites More sharing options...
reubj Posted January 5, 2014 Author Share Posted January 5, 2014 Pm sent Kkilmer87. Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 7, 2014 Share Posted January 7, 2014 I used a set off a early Ranger on Betty. I do not have the internal braces in the doors. Use fender washers behind the nuts to keep them from pulling through the door. Try to find either a factory set of a set off a Ranger. The fullsize Ford's have bigger mounting arms and look weird on a MJ's short door. Link to comment Share on other sites More sharing options...
87Warrior Posted January 7, 2014 Share Posted January 7, 2014 I have a decent set of mirrors I took off my 92 for the 97+ mirrors. Manual adjust and the black housing is faded some. I should have the plastic interior trim piece in gray as well. If interested I can take a pic then send them to you for the cost of shipping. Link to comment Share on other sites More sharing options...
