Intermittent Idle
What's up guys
I have an 88 2.5 ax5 4x4 I've been having really crazy idle...by what I mean crazy I mean that there's never a set idle this truck has since I've been driving it the past 2 years...one moment it's at normal idle(600-700 rpms) then bogs down to 100-300 rpms...I've already done the ground refreshing for this truck, the refreshing of the c101, and I haven't checked vacuum lines since I last changes them last year...I will do a brake fluid test to check for a vacuum leaks but is there any more other ideas this would lead to this crazy idling?
Well when at start up it idles fine but the first 5 min it idles a little high to get up to temperature...
Then after driving a bit getting to a stop it will idle super low (100-300 rpms) then at the next stop it will idle normal...
And just to try something I would turn it off and turn it back on it will idle normal till the next stop...this is also giving a rich smell as well
Throttle plate not seating consistently? Dirty throttle body? Dirty/sticking idle air control valve? These are easy to check and remedy - I'd start there.
By the way, that engine won't idle that slowly ("100-300 rpms") - the tachometer must be off, too.
I suppose I could always be wrong, but I always assumed since the spacing of the first line wasn't consistent with any of the other scale marks, they just started at 500 rpm. The spacing is the same going up from 500. The "500" line as I call it (you assumed 250) is also slightly thicker than the x250/x750 lines further up the scale, matching the rest of the x500 lines. One valid reason they could be skipping the first 500 rpm is that gauges are typically inaccurate at the extremities of their range. As a result, most dash gauges typically measure beyond the scale. Also, the engine likely will never be going that slowly, and probably it would stall before it dropped much below 500. It is, I grant you, a little weird that they do it this way.
Of course, this is just the assumption I've made about my tach. I could still be wrong, but I'm reasonably confident this is the way the tach should be read. If someone who actually knows one way or the other how the bottom end of the tach should be read, I'm sure everyone would appreciate if they were to chime in.
  On 12/11/2013 at 12:48 AM, gogmorgo said:
If you look at the sub-1000rpm range on your tach and compare it to the rest of the tach, you'll see that it basically skips the first 500 rpm. Looks to me like you're looking at 700 and then 600.
That's how I think it operates. I don't know for sure, but dropping the first 500 rpm makes a whole lot of sense.
Can you just replace all your vacuum lines? They're probably cracked and garbage anyway if they're original.
The vacuum lines at the intake manifold, below the throttle body could be the source of your vacuum leaks. Very common. Spraying for them with throttle body cleaner is a good idea. As suggested by gogmorgo, I would just replace them if you've never done so. You should also make sure your intake manifold bolts are snug while you're in the diagnostic mode.
Ok so I changed a few vacuum lines that caused some of the high idle caused by the throttle body cleaner spray and it helped with idle but maybe about 50rpms and while I was at it I checked the intake manifold bolts and one in the back was loose I turned it with my hand so i tightened it and idle did great and stayed at 600-700rpms then it dropped back down to about 200-300rpms but I only snugged down the top part. tomorrow when I have light I will do the bottom bolts to make sure they are tight and hopefully idle gets better and will clean the relay terminal to make sure that no dirt or junk is in that area
Make sure the EGR isn't sticky/opening when it shouldn't. The IAC is external on that and more of an idle stop. They need lubing once in awhile. Did you clean the throttle body? Gunge around the plate disrupts the air flow. When you first start it, the computer runs the "ice cold" program (like a choke), then it switches to a "warming up" phase until the engine temp is high enough to switch to the O2 feedback.
   Look down the throttlebody while it is running and see if fuel is dripping from the injector while it is idling. If so, you need a new o-ring kit although a few times I have pulled them and if it wasn't damaged, re-installed with Silglyde grease to slide it in place so it resealed.
