Retired Stormtrooper
Thanks I wasnt sure whether to do the grill pieces white or black but my gf insisted it would look better. I may go the plasti dip route in the future to see if I like it black and peel it off if I don't.
wrz I really like your XJ my first jeep was an 89 and nowhere near as clean as yours- as for the bumper lights theyre actually projector housings I took out of a set of headlights at LKQ. I installed mine using a hole saw and some liquid steel. Unfortunately the cut off is upside down so I try not to use them on the road for fear of blinding oncoming drivers. Theyre great in the woods though.
  • Replies 119
Thanks! And yeah I was planning on ditching them until I saw a picture of them in graphite online. Took a hell of a lot of prep work but I was pleased at how they turned out. I'm not totally sold on my current rims but finances may not permit a new set so Ive been searching for color options and what not.
My 89 just before I traded it
That is one sharp looking Cherokee.  I've never been a big fan of those turbine wheels, but in that color with those tires on that rig, I totally dig it.
:agree: Simple, yet very distinctive. Superb execution!
That's some nice work on the truck.  I wanted to chime in about your LED gauge lighting and the dimmer not working.  What you need is a Pulse Width Modulator to create a true dimming effect on LED lights.  Since LED's essentially operate in an on and off fashion, you are currently running at a 100% duty cycle, but to make them dim they have to be turned on and off.  The lower the duty cycle, the dimmer it appears.  Because they flash so fast, your eyes will never pick up the difference.  Many factory LED tail lights work on this principle, with low pulse width for running lights, then high for brakes.
In any case, nice project and good progress.  Sharp looking truck.
That's some nice work on the truck. I wanted to chime in about your LED gauge lighting and the dimmer not working. What you need is a Pulse Width Modulator to create a true dimming ffect on LED lights. Since LED's essentially operate in an on and off fashion, you are currently running at a 100% duty cycle, but to make them dim they have to be turned on and off. The lower the duty cycle, the dimmer it appears. Because they flash so fast, your eyes will never pick up the difference. Many factory LED tail lights work on this principle, with low pulse width for running lights, then high for brakes.
Thanks AirborneDeath and ImpulseRocket
As far as the LEDs go I am farmiliar with the modulator but it just hasnt bothered me enough for me to fix it
  • 3 weeks later...
So... Ive got something in the works but, as usual Ive hit a creative roadblock.
About a week and a half ago I came downstairs and found my drivers side door open, my head unit half ripped out, amp disconnected but still in the truck, glove box and center console rifled through and all my stuff everywhere. Looks like somebody was after my sound system but got spooked and bolted mid-heist.
My first solution was to install the 120 decibel siren I had laying around but after giving it more thought I realized I had made myself a pretty easy target- aftermarket head unit with usb and headphone jack strung up to my windshield mount, amp and sub clearly visible between the seats, etc. While in some parts of the country it may be acceptable to show off your toys, around here it makes you a target.
I picked up a stock alpine head unit from the JY and mocked it up along w some other things
Its the stock HU from an early to mid '00s Grand Cherokee. I chose it because its a Chrystler unit, it has the output for a 10 disc changer, its made by Alpine, it has a wireless rf transmitter for cordless headphones (that ill never use but still cool) and it was 15 bucks.
Since mock up I have pulled the dash and cut it up and am in the process of reassembling it into something that looks stock but incorporates the fearures I want. Here is a teaser pic for those interested and I hope to have something solid by the end of the week
Thank you
I love the truck but I'm kickin myself in the @ss for choppin up the dash...
The wiring nightmare went all the way up through the firewall and the junction box has already turned black again since I cleaned the connections about a month and a half ago. There are more unused plugs and wires that go nowhere than there are functioning parts so Ive ripped all that out and all new wiring will go in with the dash.
On a side note- for the headlights I have sourced a good length of heave gauge wire and want to run my own switch- do I need a specific one or can I use any old toggle switch for the headlights?
You could use the old switch or a toggle switch to trigger a relay for the headlights.  Then they will be direct powered by the battery/alt and be a lot brighter, and you won't need super heavy gauge wire for the switch.  I actually just did this to my truck with a few ft. of wire, H4 headlight sockets and 4/5 wire relays that I got for free from the local pick a part.  Total investment was maybe $20 and a little bit of my Rosin core solder.  Works great too.
