Spectormj Posted November 12, 2013 Share Posted November 12, 2013 Will I be able to fit 31s under my MJ if it's pretty muc stock hight? I'm gettin new tires tomarrow Link to comment Share on other sites More sharing options...
87Warrior Posted November 12, 2013 Share Posted November 12, 2013 Yes. They will fit. Might rub on LCA at full lock, but you can switch to a WJ LCA for clearance. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted November 12, 2013 Share Posted November 12, 2013 :agree: I have 31x10.5 tires on my MJ, just have minimal rubbing on the LCAs. not sure of your current engine, and gear setup, but lower gears may be needed. I started with 3.07 (kinda sucked), then swapped axles to 3.55, currently regearing to 4.10 Link to comment Share on other sites More sharing options...
Dadinator Posted November 12, 2013 Share Posted November 12, 2013 Yep. Like they said above. check out my sig pic. And my build thread. Link to comment Share on other sites More sharing options...
Tactical Bacon Posted November 12, 2013 Share Posted November 12, 2013 I have 31x10.5s on mine and they fit pretty well. The front coils sag some, so I can't hit some bumps too fast and they rub at full lock, but they fill the wheel well quite nicely. It's a 4.0 HO with an AX15 and stock 3.07 in the rear but I haven't really had any problems getting up and going. Link to comment Share on other sites More sharing options...
Spectormj Posted November 12, 2013 Author Share Posted November 12, 2013 I've got 2.8 v6 under the hood Hopefully it has enough power Link to comment Share on other sites More sharing options...
Tactical Bacon Posted November 12, 2013 Share Posted November 12, 2013 On 11/12/2013 at 11:34 PM, Spectormj said: I've got 2.8 v6 under the hood Hopefully it has enough power Automatic or manual? Rear gear ratios will depend on that factor and will help or hurt you. Link to comment Share on other sites More sharing options...
Spectormj Posted November 12, 2013 Author Share Posted November 12, 2013 Auto Link to comment Share on other sites More sharing options...
jimoshel Posted November 13, 2013 Share Posted November 13, 2013 I have two MJ'S and a XJ with 31's.One MJ will rub the LCA on a tight turn. The other MJ and XJ has no problem. Never worried about it or checked it but now I'm wondering if the stops might have something to do with it. Link to comment Share on other sites More sharing options...
Tactical Bacon Posted November 13, 2013 Share Posted November 13, 2013 On 11/12/2013 at 11:40 PM, Spectormj said: Auto You should have 3.55 differential gears, then. That'll help with the torque multiplication. On 11/13/2013 at 12:22 AM, jimoshel said: I have two MJ'S and a XJ with 31's.One MJ will rub the LCA on a tight turn. The other MJ and XJ has no problem. Never worried about it or checked it but now I'm wondering if the stops might have something to do with it. Noticeable difference in how far the wheels will turn? Link to comment Share on other sites More sharing options...
jimoshel Posted November 13, 2013 Share Posted November 13, 2013 On 11/13/2013 at 12:48 AM, 91Comanche91Kid said: On 11/12/2013 at 11:40 PM, Spectormj said: Auto You should have 3.55 differential gears, then. That'll help with the torque multiplication. On 11/13/2013 at 12:22 AM, jimoshel said: >>I have two MJ'S and a XJ with 31's.One MJ will rub the LCA on a tight turn. The other MJ and XJ has no problem. Never worried about it or checked it but now I'm wondering if the stops might have something to do with it. Noticeable difference in how far the wheels will turn? Never noticed any but then I wasn't looking for any. Gonna pay closer attention next time I drive them and see if I can notice any. Also one of the MJ'S is a '86 with the fabled 2.8 and 3:54 gears. Just a bit sluggish of the line but not enough to bother me any. I think 3:73 would be just right for that combination. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 13, 2013 Share Posted November 13, 2013 I've got 31's on my XJ with 4.10's , AW4 auto and I6. They turn good with the 4.10's, can even spin them if need be, but I don't since my trans. has 210k miles on it. I was always told that 31's wouldn't fit on a stock XJ without lift or fender trimming. Mine rubbed slightly with 3 inches of lift. How come they fit with no rubbing on an MJ as y'all claim? Link to comment Share on other sites More sharing options...
Tactical Bacon Posted November 13, 2013 Share Posted November 13, 2013 On 11/13/2013 at 1:14 AM, jimoshel said: On 11/13/2013 at 12:48 AM, 91Comanche91Kid said: On 11/12/2013 at 11:40 PM, Spectormj said: Auto You should have 3.55 differential gears, then. That'll help with the torque multiplication. jimoshel said: >>>I have two MJ'S and a XJ with 31's.One MJ will rub the LCA on a tight turn. The other MJ and XJ has no problem. Never worried about it or checked it but now I'm wondering if the stops might have something to do with it.lockquote>Noticeable difference in how far the wheels will turn? Never noticed any but then I wasn't looking for any. Gonna pay closer attention next time I drive them and see if I can notice any. Also one of the MJ'S is a '86 with the fabled 2.8 and 3:54 gears. Just a bit sluggish of the line but not enough to bother me any. I think 3:73 would be just right for that combination. Well he could get out there and check his rear gear ratio, but I agree; 3.73 sounds golden. On 11/13/2013 at 1:51 AM, onlyinajeep726 said: I've got 31's on my XJ with 4.10's , AW4 auto and I6. They turn good with the 4.10's, can even spin them if need be, but I don't since my trans. has 210k miles on it. I was always told that 31's wouldn't fit on a stock XJ without lift or fender trimming. Mine rubbed slightly with 3 inches of lift. How come they fit with no rubbing on an MJ as y'all claim? Well mine rubs on the driver side if I hit a bump too hard and they do rub at full lock. Both of the inner fender wells are gone up front on my MJ. Backspacing may be part of it. My tires are on Canyon wheels 15x8 with 5.5" backspacing. As far as turning them over, I tried dumping the clutch at about 3k rpm the other day and holy crap! It sounded like I was breaking the world from the way something slammed haha. Link to comment Share on other sites More sharing options...
Eagle Posted November 13, 2013 Share Posted November 13, 2013 On 11/13/2013 at 1:51 AM, onlyinajeep726 said: I've got 31's on my XJ with 4.10's , AW4 auto and I6. They turn good with the 4.10's, can even spin them if need be, but I don't since my trans. has 210k miles on it. I was always told that 31's wouldn't fit on a stock XJ without lift or fender trimming. Mine rubbed slightly with 3 inches of lift. How come they fit with no rubbing on an MJ as y'all claim? 31s fit a stock XJ the same as they fit a stock MJ -- slight rubbing on the LCAs at full steering lock. I have 31s on the '88 XJ (on factory rims) and have had no issues (other than the LCA rubbing, which I don't consider to be an "issue") for two-plus years. The key is that the 31s have to be on factory Jeep rims. No aftermarket rims have 5-1/4" backspacing like the factory rims, so on aftermarket rims the tires sit farther outboard and hit the flares. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 13, 2013 Share Posted November 13, 2013 On 11/13/2013 at 2:57 AM, Eagle said: The key is that the 31s have to be on factory Jeep rims. No aftermarket rims have 5-1/4" backspacing like the factory rims, so on aftermarket rims the tires sit farther outboard and hit the flares. That's probably exactly it. Didn't really take that into account until you mentioned it. My XJ has 15" x 8" steelies with 4.00" backspace. Rubbed like a mofo in turns until some slight trimming and added lift. Link to comment Share on other sites More sharing options...
drase Posted November 13, 2013 Share Posted November 13, 2013 On 11/13/2013 at 2:57 AM, Eagle said: On 11/13/2013 at 1:51 AM, onlyinajeep726 said: I've got 31's on my XJ with 4.10's , AW4 auto and I6. They turn good with the 4.10's, can even spin them if need be, but I don't since my trans. has 210k miles on it. I was always told that 31's wouldn't fit on a stock XJ without lift or fender trimming. Mine rubbed slightly with 3 inches of lift. How come they fit with no rubbing on an MJ as y'all claim? 31s fit a stock XJ the same as they fit a stock MJ -- slight rubbing on the LCAs at full steering lock. I have 31s on the '88 XJ (on factory rims) and have had no issues (other than the LCA rubbing, which I don't consider to be an "issue") for two-plus years. The key is that the 31s have to be on factory Jeep rims. No aftermarket rims have 5-1/4" backspacing like the factory rims, so on aftermarket rims the tires sit farther outboard and hit the flares. This is true. I have 31's on Jeep Wrangler rims with Spidertrax spacers and a 3" Rusty's lift. Still rub on flares, left more than right. I can only turn halfway then major rubbing. If I take the front flares off I might be alright but I think I'm going to get Bushwackers as I like the stance of the wheels. But yes, I learned the hard way that non stock wheels on 31's can rub even with a lift and spacers. Link to comment Share on other sites More sharing options...
earl*t Posted November 13, 2013 Share Posted November 13, 2013 Quite the discussion on 31s. Looks like the thread is having a little struggle staying on topic. 31s will fit without a lift but will rub LCA. More specifically, 1 - Rims must be factory width (7"), diameter (15"), and offset (5 1/4") 2 - Tire size = 31"x10.5" or less 3 - Lower Control Arms need replaced with WJ LCA, or equivalent, to prevent tire rub Is this an accurate observation? Link to comment Share on other sites More sharing options...
Tactical Bacon Posted November 13, 2013 Share Posted November 13, 2013 On 11/13/2013 at 9:56 PM, earl*t said: Quite the discussion on 31s. Looks like the thread is having a little struggle staying on topic. 31s will fit without a lift but will rub LCA. More specifically, 1 - Rims must be factory width (7"), diameter (15"), and offset (5 1/4") 2 - Tire size = 31"x10.5" or less 3 - Lower Control Arms need replaced with WJ LCA, or equivalent, to prevent tire rub Is this an accurate observation? I think that covers all the bases, though you probably could squeeze another inch of diameter in there. But then again, we don't want to confuse anyone haha. Link to comment Share on other sites More sharing options...
Oyaji Posted November 13, 2013 Share Posted November 13, 2013 On 11/13/2013 at 10:17 PM, 91Comanche91Kid said: On 11/13/2013 at 9:56 PM, earl*t said: Quite the discussion on 31s. Looks like the thread is having a little struggle staying on topic. 31s will fit without a lift but will rub LCA. More specifically, 1 - Rims must be factory width (7"), diameter (15"), and offset (5 1/4") 2 - Tire size = 31"x10.5" or less 3 - Lower Control Arms need replaced with WJ LCA, or equivalent, to prevent tire rub Is this an accurate observation? I think that covers all the bases, though you probably could squeeze another inch of diameter in there. But then again, we don't want to confuse anyone haha. For clarification on #3 above - add "OR adjust steering stops to avoid minimal tire rub", right? Link to comment Share on other sites More sharing options...
earl*t Posted November 14, 2013 Share Posted November 14, 2013 On 11/13/2013 at 9:56 PM, earl*t said: 31s will fit without a lift but will rub LCA. More specifically, 1 - Rims must be factory width (7"), diameter (15"), and offset (5 1/4") 2 - Tire size = 31"x10.5" or less 3 - Lower Control Arms need replaced with WJ LCA, or equivalent, OR adjust steering stops to prevent tire rub Hey Kid, there is an incredible amount of confusion on this topic. :thumbsup: Jp magazine published a lift/tire fitment chart that presents data which conflicts with what has been established here. I attempted but was unable to copy it to this thread. Perhaps a tech savvy member can accomplish the task? At any rate, the combined real world experience of our contributors is contrary to the publication. Link to comment Share on other sites More sharing options...
Oyaji Posted November 14, 2013 Share Posted November 14, 2013 On 11/14/2013 at 12:17 AM, earl*t said: On 11/13/2013 at 9:56 PM, earl*t said: 31s will fit without a lift but will rub LCA. More specifically, 1 - Rims must be factory width (7"), diameter (15"), and offset (5 1/4") 2 - Tire size = 31"x10.5" or less 3 - Lower Control Arms need replaced with WJ LCA, or equivalent, OR adjust steering stops to prevent tire rub Hey Kid, there is an incredible amount of confusion on this topic. :thumbsup: Jp magazine published a lift/tire fitment chart that presents data which conflicts with what has been established here. I attempted but was unable to copy it to this thread. Perhaps a tech savvy member can accomplish the task? At any rate, the combined real world experience of our contributors is contrary to the publication. . Link please? . As follows below, I took the liberty of editing your summation for clarity, making some slight changes and adding a couple of questions. Is this indeed the consensus, and can the knowledgeable answer the highlighted questions please? . . 31s will fit without a lift but will rub LCA. More specifically: Rims must have factory backset (5 1/4") [***what are the wheel width limitations? and is there any wheel diameter limitation?] Tire size = 31"x10.5" or less Lower Control Arms replaced with WJ LCA or equivalent [***is there any other substitute for the WJ LCA?], OR steering stops adjusted to prevent tire rub Link to comment Share on other sites More sharing options...
Dadinator Posted November 14, 2013 Share Posted November 14, 2013 Mine has 15X8 TJ rims. Gamblers. Only rubbing on LCA's. Link to comment Share on other sites More sharing options...
Oyaji Posted November 14, 2013 Share Posted November 14, 2013 On 11/14/2013 at 12:58 AM, Dadinator said: Mine has 15X8 TJ rims. Gamblers. Only rubbing on LCA's. Thought so. "Gamblers" are the factory 5-hole wheels, right? Those are the ones that would be my choice for a 15" wheel... but I would prefer a 16" or 17" wheel (even if only plain steel ones) if available to run 31s without rubbing. Anyone have info on any such options? Link to comment Share on other sites More sharing options...
Tactical Bacon Posted November 14, 2013 Share Posted November 14, 2013 I'll reiterate only rubbing LCAs with my 15x8 Canyons. Link to comment Share on other sites More sharing options...
earl*t Posted November 14, 2013 Share Posted November 14, 2013 Jp link WJ LCA alternative :eek: 33s? http://www.rustysoffroad.com/rustys-control-arms-custom-for-stock-wheels-pair.html Link to comment Share on other sites More sharing options...
