akamcbird Posted April 12, 2007 Share Posted April 12, 2007 it looks like my 86 GM comanche had a few things done to the leaves(looks like aal for load capacity as well as a bolt on set of overloads) and i'd like to bring it closer to stock as i have zero flex in the rear. does anyone have pics of their stock leaf pack for me to referance? much appreciated-terence Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 12, 2007 Share Posted April 12, 2007 remove the overload spring and you'll get more flex. that's one of mine...stock springs but it's SOA. edit: [see what Pete says below....] Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2007 Share Posted April 12, 2007 Pay no attention to the man behind the curtain. Do not remove the overload! It doesn't inhibit flex much at all and goes a long way towards fighting spring-wrap. Link to comment Share on other sites More sharing options...
feerocknok Posted April 12, 2007 Share Posted April 12, 2007 Standard factory packs are 3 leaves, plus an overload spring. Metric ton factory packs are 4 leaves, plus an overload. And yeah to what Pete said. You'll get alot of sagging real quick if you pull the overloads. Link to comment Share on other sites More sharing options...
jbhill Posted April 12, 2007 Share Posted April 12, 2007 theres what you can see of the leafs on my 91 4.0 2wd... Link to comment Share on other sites More sharing options...
tjbliley Posted April 12, 2007 Share Posted April 12, 2007 Hey Jeff!!! I know you have great pics of your springs cause I saw you take them when we did the swap. Cough them up. MJeff has some great shots that will show you everything you need. Link to comment Share on other sites More sharing options...
akamcbird Posted April 12, 2007 Author Share Posted April 12, 2007 that first pic should do it... i just didnt know how many or which ones were original .now I'm just woried ill lose hight. its got 6 leaves and that bolt on POS does effect flex. i know this because i have near zero flex ill setup pics in a moment Link to comment Share on other sites More sharing options...
akamcbird Posted April 13, 2007 Author Share Posted April 13, 2007 thats what ive got... ill start by removing the bolt on then see what hapens 4 separate units two per side, one in front and one behind the axle Link to comment Share on other sites More sharing options...
feerocknok Posted April 13, 2007 Share Posted April 13, 2007 thats what ive got... ill start by removing the bolt on then see what hapens 4 separate units two per side, one in front and one behind the axle :redX: Link to comment Share on other sites More sharing options...
Twisty Posted April 13, 2007 Share Posted April 13, 2007 I was contemplating not putting in the overload leaf when I was rebuilding my packs, but I ended up doing so. I'm glad I did because after the SOA, the overload leaf is touching the next leaf up at both ends...without the help of the overload leaf I'm sure I would have less height and more spring wrap like Pete said. :USAflag: Link to comment Share on other sites More sharing options...
mjeff87 Posted April 13, 2007 Share Posted April 13, 2007 Bunch of ‘em here: and here: and a couple here, too: :cheers: HTH, Jeff Link to comment Share on other sites More sharing options...
akamcbird Posted April 14, 2007 Author Share Posted April 14, 2007 removed the bolton pos and my axle moves huray (lost 1/2" on the passenger side) also noticed the bottom most leaf (stiff shorty) on one side was put on backwords...no biggy ill deal with it later. all the springs were for a camper (i think, there are remnents of tiedown mounts on the frame) Link to comment Share on other sites More sharing options...
mjcanoe Posted April 14, 2007 Share Posted April 14, 2007 akamcbird, good advice so far, just remember that an aal comes in 2 vareties, thick & short for load or thin & long which adds less lift, but gives better ride/flex. As mentioned do not remove overload leaf, disaster will visit you. OEM manual shows 4 leafs including overload for d35 rears. mjcanoe Link to comment Share on other sites More sharing options...
