Oversize Battery
It a good idea to run the largest battery you can ,it will provide more reserve capacity ,as well as crank amps.. I run a group 65, its the largest that will fit in my MJ.
This is true. The largest group battery that will bolt in using the original hardware and not interfere with hood clearance is a group 34 battery, as used in the 97 and up XJs. It's has about 20% more CCA than the stock group 58 series and requires no modifications. I'm not sure the group 65 battery will do that. But if it does, I'd like to know.
Cruiser; just looked up the Group 65 and it is larger than the Group 34 battery. You might want to verify the group 65 measurements for an unmolested fit? Bigger is always better.  :yes:
Group... L................W................H
65..........12 1/16......7 1/2...........7 9/16
34..........10 1/4........6 13/16.......7 7/8
Did the Group 34 Interstate swap today. 700 CCA. Bolts right in. Can't use the bracket from the front stud to the header panel. Who cares.
Hmmm. The battery tray must be a bit lower in the HOs then. Reused the bracket and it fit well. It's sure not a critical piece though.
  • 4 weeks later...
So, after re-reading this thread,a group 34 battery is able to use the OEM group 58 battery hold-down bar? Can anyone confirm?
Yes, you can use the original hold-down bar.
Even tho I've seen this so many times I still can't get over how clean it is under there
^^  Old pic. It's much cleaner now.  :yes:   Too bad I don't keep the rest of my stuff clean, like the yard, the man cave, the garage, the deck, etc etc.
