Sport Decal Removal.
if you have a body shop supp;y in your area ask for a silicon wheel (explain what you want it for and they will point you in the right direction)
aside from that.....check out my avitar.......nice truck.... . :MJ 1: .
I believe they are vinyl decals. At least, my '91 Sport decals are. If you don't want to just take them off with a wheel, a heat gun and something sharp (credit card?) will help. If you don't have a heat gun, parking it in the sun will help soften them up also.
Thanks I believe I will try to use the eraser as Alex suggested. Yes I'm plan on painting. Thanks for the replies.
This is the one I am talking about
http://solutions.3m.com/wps/portal/3M/en_US/Marine/Home/Products/Catalog/?PC_7_RJH9U5230GE3E02LECIE20S4K7000000_nid=H6SGG1DDTVbeRJ5GMFSMV0gl
I think it is the same as the one listed above. It is the product they use in pro body shops as well as by the grafic companies that install decals for a living.....when in doubt use what the pros use  :thumbsup:
One of these! Note, it says that it will not mar the finish, but I found that a light buffing would be required. I believe you are planning on painting anyway though.
http://www.amazon.com/Industries-Smart-Eraser-Drill-Adaptor/dp/B00488DDB8/ref=pd_sim_indust_5
 This is what I use to remove decals, pinstripes, tree sap from paint. Works great. Just make sure you keep it moving and don't let it burn the paint.
