Towed Home For The First Time.
yesterday I was on my way home from the junkyard, and i was coming up to a red light when the truck made an awful clunk, and the truck lurched like it popped out of gear. i was able to drive a short distance to a small parking lot. so i started by shifting the tc into 2wd (it was in full time) i pulled forward and back a short distance and it still was clanking, then i removed the front drive shaft, and again it was still clunking. dad noticed that when i pulled forward at some point the rear shaft sorta stops rotating and the diff case rotates upward only for it to snap back into place... I haven't done any off roading sense i installed the rear Aussie locker. the engine still runs fine (aside from overheating due to a bad pressure bottle)
I haven't started looking at it yet, hopefully i can tomorrow.
I think it may be:
Broken ring or pinion
TC case issue (broken gear?)
575461_10200994784372338_1385005712_n.jp
however on the plus side while i waited the 1 1/2 to 2 hours for the tow truck i was able to swap the old plastic dash bezel to a wood grain.
:thumbsup: on the wood grain, love those things. I really need to find one to go with my black interior.
Here's to hoping for an easy fix. I would lean towards rear end issue, but couldn't say for sure.
Picked up a wood grain bezel at P&P for my '88. Gonna put that puppy on, if I ever get the dash back in. Picked up several other little upgrades for the MJ there. Now I've just got to get it all back together and running so I can install everything. Why is it every time you fix one thing you discover two more that need to be fixed?
It's a boost gauge. Probably using just the vacuum side unless it's just an ornament. :yes:
Yes it's a boost / vacuum gauge. I have another insert from a jeep without a clock that I am going to use instead of that one. This way there is not a hole where the clock part was. The vacuum gauge is nice, and its also cool to have a responsive needle lol
Back when mechanics were real men and not glorified computer analysts the vacuum gauge was one of their most useful tools for analyzing an ailing engine. They were also a valuable aide for knowledgeable drivers wanting to get the most out of their machine.
How come there's no icon of a soap box?
How come there's no icon of a soap box? :soap box:
There ya go Jim ;)
Anyway, whats the "Power/Comfort switch do in a Manual Trans truck? Haha also post of some pics of the damage when ya find out the cause. Good Luck :thumbsup:
There are two different springs on the clutch pedal. A strong one and a weaker one. In the 'Power' position the stronger spring is used, bringing the clutch pedal up faster. In the 'comfort' position the weaker spring is used requiring less foot pressure.
Thank you for the icon..
:laughin:
Jim, when you click on the button for the smiley's, it'll pop up the bar on the bottom with them.  Off to the right there's a tiny arrow to go to the next page of them.  Took me awhile to notice that.
