rmoore1031 Posted April 16, 2013 Share Posted April 16, 2013 I asked Jeep for the build sheet for my 1988 MJ. They said that they couldn't give me it since it is too old. Anyone else have this problem? They gave me one for my 1990 XJ. Link to comment Share on other sites More sharing options...
AeroNautical Posted April 16, 2013 Share Posted April 16, 2013 If you don't mind taking the panel off your drivers side door, that's where I found mine. Not sure if that's common to be there or not. Link to comment Share on other sites More sharing options...
jimoshel Posted April 16, 2013 Share Posted April 16, 2013 I found one for an '87 behlnd the seat back. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 16, 2013 Share Posted April 16, 2013 The 86, 87, 88 build sheet info is sketchy due to being under AMC ownership and not all the info transferring over. If you post your VIN here or PM it to me I can probably get you a little info, like where it was sold, when, and build date info through Chrysler. If there is a build sheet it will only be codes with no descritions. You might be able to find a Chrysler build code book in that case and translate the codes. Link to comment Share on other sites More sharing options...
rmoore1031 Posted April 16, 2013 Author Share Posted April 16, 2013 Thanks for the tips guys. I've taken the driver's panel off once or twice and didn't find it there. Maybe I'll have better luck when I tear apart the interior. VIN is 1JTHS6415JT038387. I know its a a 1988 Jeep Comanche, 2WD, I4, Shortbed, manual everything. What I'm trying to find out is the trim and sun roof history. I think its a base model or maybe pioneer with a dealer option sun roof. I have access to a Chrysler build code book somewhere online so a build sheet would be awesome! Thanks. Link to comment Share on other sites More sharing options...
airspeed Posted April 16, 2013 Share Posted April 16, 2013 I found the build sheet on my 88 tucked up under the seat springs on the passenger side. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 16, 2013 Share Posted April 16, 2013 i've found the build sheets behind driver or passenger door panel, in each b pillar behind the trim, behind the rear wall carpet, under the seat springs, under the center console... Â AMC didn't do anything the same twice in a row... Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 16, 2013 Share Posted April 16, 2013 Build Date: Â Â September 8, 1987 Â Last known and original owner lived in Fort Drum, NY Â Selling Dealer: Â Â 23149 - SCERBO AUTO CENTER Sales Type: 1 - DIRECT RETAIL City: Â Â PARSIPPANY State/Province: NJ Country: Â Â USA Telephone: (201)335-1313 Â Â Optional Equipment Code Description Code Description Code Description *B1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE AGC DESCRIPTION NOT AVAILABLE APA DESCRIPTION NOT AVAILABLE CBA DESCRIPTION NOT AVAILABLE CGX DESCRIPTION NOT AVAILABLE DCB DESCRIPTION NOT AVAILABLE EPD DESCRIPTION NOT AVAILABLE GAC DESCRIPTION NOT AVAILABLE GSC DESCRIPTION NOT AVAILABLE JJA DESCRIPTION NOT AVAILABLE KD8 DESCRIPTION NOT AVAILABLE LAP DESCRIPTION NOT AVAILABLE LMA DESCRIPTION NOT AVAILABLE MDA DESCRIPTION NOT AVAILABLE NAA DESCRIPTION NOT AVAILABLE PE4 DESCRIPTION NOT AVAILABLE QE4 DESCRIPTION NOT AVAILABLE SBA DESCRIPTION NOT AVAILABLE TBG DESCRIPTION NOT AVAILABLE WMC DESCRIPTION NOT AVAILABLE Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 16, 2013 Share Posted April 16, 2013 Thats all Chrysler has on your 87. The build codes are the three digit (Letters) in between all the "descrition not available" things. Like I said, you might be able to look the codes up somewhere. Hope this helps. Sorry, can't give you the original or last known owner info. Link to comment Share on other sites More sharing options...
Minuit Posted April 16, 2013 Share Posted April 16, 2013 If it wouldn't trouble you, could you run mine through too? Wondering if I can get a day of assembly on it, I know it was sometime in April. 1J7FT26S9ML600717 Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 16, 2013 Share Posted April 16, 2013 If it wouldn't trouble you, could you run mine through too? Wondering if I can get a day of assembly on it, I know it was sometime in April. 1J7FT26S9ML600717   Vehicle Service Information Year/Model: 1991 JEEP COMANCHE Last Odometer: 8,129 miles on September 22, 1992 Body Style: MJTL61 In-Service Date: November 22, 1991 Engine: ERH-4.0L I6 Power Tech Engine In-Service Odometer: 33 miles Transmission: DGS-4-Speed Automatic AW4 Transmission Odometer Type: miles Color 1: PAC-Silver Star Metallic Clear Coat Car Line: P Color 2: QAC-Silver Star Metallic Clear Coat Build Date: April 17, 1991 Current Market Register: U Hour: 12  Vehicle Sale Information Selling Dealer: 23911 - UNDERHILL MOTORS Sales Type: 1 - DIRECT RETAIL City: DICKSON State/Province: TN Country: USA Telephone: (615)446-8855   Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GUAS Pwr Htd Drvr Memory Mirrors, F/Away JAZS Analog Instrument Cluster JCAS 85 MPH Primary Speedometer KDNS DESCRIPTION NOT AVAILABLE KWSS DESCRIPTION NOT AVAILABLE K3ZS DESCRIPTION NOT AVAILABLE LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Bright Windshield Moldings MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings MMJS DESCRIPTION NOT AVAILABLE NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QACS Silver Star Metallic Clear Coat RA8S Delete Radio SCES Alcantara Wrap Steering Wheel SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 164S Zone 64-Memphis  Optional Equipment Code Description Code Description Code Description *B1 DESCRIPTION NOT AVAILABLE -SA DESCRIPTION NOT AVAILABLE ALA SE Decor Group ALK Motown Package BAFP 130 Amp Alternator BCDP 500 Amp Maintenance Free Battery CBAP Straight Back Bench Seat CKJP Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DHTP Elec,Shift-on-the-Fly,P/Time T/Case ERH 4.0L I6 Power Tech Engine GRVP Left Manual Mirror HAA Air Conditioning JJAA Cigar Lighter MBJA Black Front Bumper PAC Silver Star Metallic Clear Coat SBAA Power Rack and Pinion Steering TNCA P195/65R15 BSW AS Touring Tires TZHP Michelin Brand Tires WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 3VQA Customer Preferred Discount Link to comment Share on other sites More sharing options...
rmoore1031 Posted April 17, 2013 Author Share Posted April 17, 2013 Â Build Date: Â Â September 8, 1987 Â Last known and original owner lived in Fort Drum, NY Â Selling Dealer: Â Â 23149 - SCERBO AUTO CENTER Sales Type: 1 - DIRECT RETAIL City: Â Â PARSIPPANY State/Province: NJ Country: Â Â USA Telephone: (201)335-1313 Â Â Optional Equipment Code Description Code Description Code Description *B1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE AGC DESCRIPTION NOT AVAILABLE APA DESCRIPTION NOT AVAILABLE CBA DESCRIPTION NOT AVAILABLE CGX DESCRIPTION NOT AVAILABLE DCB DESCRIPTION NOT AVAILABLE EPD DESCRIPTION NOT AVAILABLE GAC DESCRIPTION NOT AVAILABLE GSC DESCRIPTION NOT AVAILABLE JJA DESCRIPTION NOT AVAILABLE KD8 DESCRIPTION NOT AVAILABLE LAP DESCRIPTION NOT AVAILABLE LMA DESCRIPTION NOT AVAILABLE MDA DESCRIPTION NOT AVAILABLE NAA DESCRIPTION NOT AVAILABLE PE4 DESCRIPTION NOT AVAILABLE QE4 DESCRIPTION NOT AVAILABLE SBA DESCRIPTION NOT AVAILABLE TBG DESCRIPTION NOT AVAILABLE WMC DESCRIPTION NOT AVAILABLE Thank you for your help. I'll have to find that decoder sometime. Â The previous owner was my brother who is ASE certified and I helped him with some work to the MJ. I'm still hoping to find it in the interior somewhere. Link to comment Share on other sites More sharing options...
92tanMJ Posted April 17, 2013 Share Posted April 17, 2013 I found mine under the bench seat on the passenger side, but it wasnt really legable Link to comment Share on other sites More sharing options...
Minuit Posted April 17, 2013 Share Posted April 17, 2013 Oh wow, that was unexpected. Tomorrow will be my truck's 22nd birthday. Thanks a bunch. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 17, 2013 Share Posted April 17, 2013 Since this is what's going on and Chrysler only sent me a build sheet when I contacted them, would it be too much work to run my vin as well? 1J7FJ36S3M1570755. Fair warning, it's a Canadian truck, don't know if that makes a difference. It is a '91. I don't need the build sheet, if that makes your job any easier. I'd just like a little more history than Chrysler gave me. I don't even know the build date, since it's worn off the door sticker. Link to comment Share on other sites More sharing options...
54bobby Posted April 17, 2013 Share Posted April 17, 2013 If it wouldn't trouble you, could you run mine through too? Wondering if I can get a day of assembly on it, I know it was sometime in April. 1J7FT26S9ML600717 a little auto check for you. http://charlieobaugh.com/AutoCheckReport.aspx?vin=1j7ft26s9ml600717#full-history Link to comment Share on other sites More sharing options...
92tanMJ Posted April 17, 2013 Share Posted April 17, 2013  If it wouldn't trouble you, could you run mine through too? Wondering if I can get a day of assembly on it, I know it was sometime in April. 1J7FT26S9ML600717 a little auto check for you. http://charlieobaugh.com/AutoCheckReport.aspx?vin=1j7ft26s9ml600717#full-history Dang how did you get that?? Link to comment Share on other sites More sharing options...
54bobby Posted April 17, 2013 Share Posted April 17, 2013 i'm on a bmw forum and them guys come up with this $#!&. the links never work for long cause the dealerships they are for get wise. use it while it's still available. Link to comment Share on other sites More sharing options...
Minuit Posted April 17, 2013 Share Posted April 17, 2013 Thanks, bobby. In '96 my truck was registered in Montana. I knew my grandparents traveled but I didn't think it was that far. . :MJ 1: . Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 18, 2013 Share Posted April 18, 2013 Since this is what's going on and Chrysler only sent me a build sheet when I contacted them, would it be too much work to run my vin as well? 1J7FJ36S3M1570755. Fair warning, it's a Canadian truck, don't know if that makes a difference. It is a '91. I don't need the build sheet, if that makes your job any easier. I'd just like a little more history than Chrysler gave me. I don't even know the build date, since it's worn off the door sticker.  Could you re check your VIN for me. It comes up as not found through Chrysler. Theres no reason I shouldnt be able to look up Canadian Vehicle VINs this way as well. Thanks Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 18, 2013 Share Posted April 18, 2013  Since this is what's going on and Chrysler only sent me a build sheet when I contacted them, would it be too much work to run my vin as well? 1J7FJ36S3M1570755. Fair warning, it's a Canadian truck, don't know if that makes a difference. It is a '91. I don't need the build sheet, if that makes your job any easier. I'd just like a little more history than Chrysler gave me. I don't even know the build date, since it's worn off the door sticker.  Could you re check your VIN for me. It comes up as not found through Chrysler. Theres no reason I shouldnt be able to look up Canadian Vehicle VINs this way as well. Thanks  Just looked your VIN over, It appear there are too many numbers at the end. It should only be 6 numbers. I Changed the 1 to an L and have a good Canadian VIN lookup, just want to make sure its yours. let me know. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 18, 2013 Share Posted April 18, 2013 Oh, yeah, that's mine. I just pulled that off a sticky note I've had on my desk for quite some time. Looks like I copied it down wrong from my registry entry where it's all in lower case. It's an L everywhere else. Sorry bout that. Corrected the sticky note, too! Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 18, 2013 Share Posted April 18, 2013 Vehicle Service Information Year/Model:   1991 JEEP COMANCHE Last Odometer: 16,940 kilometers on December 3, 1991 Body Style:   MJJL62 In-Service Date: February 8, 1991 Engine:   ERH-4.0L I6 Power Tech Engine In-Service Odometer: 25 kilometers Transmission:   DGS-4-Speed Automatic AW4 Transmission Odometer Type: kilometers Color 1:   PB8-DESCRIPTION NOT AVAILABLE Car Line: P Color 2:   QB8-DESCRIPTION NOT AVAILABLE Build Date: January 22, 1991 Current Market Register:   C Hour: 13  Incomplete Recall Recall Number Description Part Number Launch Date 564 FUEL RAIL BLOCKER BRK.(CAN. ONLY) SEE RECALL NOTICE February 10, 1994 747 DISC BRAKE ROTORS 05015965AA,05015965AA March 5, 1998   Vehicle Sale Information Selling Dealer:   C9783 - NORTH END JEEP EAGLE Sales Type: 1 - DIRECT RETAIL City:   PORTAGE LA PRAIRIE State/Province: MB Country:   CAN Telephone: (204)857-4971    Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GTZS Manual Remote Mirrors JDBS 180 KPH Primary Speedometer K3LS DESCRIPTION NOT AVAILABLE LBCS Glove Box Lamp LMAS Halogen Headlamps LMKS Daytime Running Headlamps, High Beam MB1S Black Front Bumper MDAS Front License Plate Bracket MFFS Black Grille MMCS Rear Qtr Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF5S DESCRIPTION NOT AVAILABLE NHKS Engine Block Heater QB8S DESCRIPTION NOT AVAILABLE SBAS Power Rack and Pinion Steering SCES Alcantara Wrap Steering Wheel SFAS Standard Duty Shock Absorbers SGAS Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box YACS Build To Canada Mkt. Specifications Z5AS GVW/Payload Rating 1ABS Canada Dealer Retail 125S Zone 25-Canada-Alberta  Optional Equipment Code Description Code Description Code Description *A8 DESCRIPTION NOT AVAILABLE -SA DESCRIPTION NOT AVAILABLE ACC Commemorative Edition Group ADA Light Group ADLA Skid Plate Group ARL Kicker/SRT Livin' Loud Audio System BAFP 130 Amp Alternator BCYP DESCRIPTION NOT AVAILABLE CACP Low Back Bucket Seats CDBP Reclining Front Seats CKAP Carpets - Floor and Cargo Area CUMP Mini Floor Console DGB All 4-Speed Automatic Transmissions DHSP Floor Mount Automatic Shift Lever ERH 4.0L I6 Power Tech Engine GFDA Rear Sliding Window GNCP Sun Visors w/Illum Vanity Mirrors GRZP Left Remote Mirror GSZP Right Remote Control Mirror HAA Air Conditioning JAYA Instrument Cluster w/Tach JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KKSP DESCRIPTION NOT AVAILABLE KWSP DESCRIPTION NOT AVAILABLE K2BP DESCRIPTION NOT AVAILABLE K27P Do Not Use LAJP Headlamps On Warning Chimes LBBP Courtesy Lamps LBDP Ash Tray Lamp LBEP Cigar Lighter LDAP Underhood Lamp LHDP Headlamp Off Time Delay MBJP Black Front Bumper MHAP Black Windshield Moldings MMKP Hi Black Gloss/Black Mirror Molding NHM Speed Control PB8 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCDP 4 Speakers SUA Tilt Steering Column TBBA Full Size Spare Tire TRN P225/75R15 OWL Wrangler AT Tires TZAP Goodyear Brand Tires WJN 15 Aluminum Wheels WLZC All Aluminum Wheels YGAA Without Billable Fuel Z01P Rear Spring Group I Z67P Left Front Spring Group XVI Z86P Right Front Spring Group XV 3N8A Drive Away Program Tracking 4CPA Federal A/C Excise Tax 4HC Special Scheduling Condition III  Link to comment Share on other sites More sharing options...
gogmorgo Posted April 18, 2013 Share Posted April 18, 2013 Cool, thanks! Doesn't look like it's made it too far... maybe 150 miles from where it was sold. Until now. Although with 300k miles, you really don't know. Except that it's got new brake rotors put on by me, I wonder what would happen if I showed up at a dealer asking for them recalls? haha. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 19, 2013 Share Posted April 19, 2013 The recalls are still good. If you go, they will do it. Link to comment Share on other sites More sharing options...
