jimoshel Posted April 2, 2013 Posted April 2, 2013 Swapped out the old gas water heater for a shiny new electric one today. It was still working but it was over 14 years old and the electric Co-op was giving away new ones to get people to swap. Seemed like a good deal to me. Unhooked all the pipes, chimney and stuff, got it outside and carried it the 2 miles to the gulley I use for a trash dump. When I set it down by the edge of the gulley I got to thinking it might have been easier to carry if I had drained it first. So I carried it back up to the house and drained it. Then carried it back to the gulley. I was right. It WAS lighter. :eek: Got the electric one all hooked. Must have did it right because it works. Lots of hot water and no leaks, or smoke. :banana:
onlyinajeep726 Posted April 2, 2013 Posted April 2, 2013 Swapped out the old gas water heater for a shiny new electric one today. It was still working but it was over 14 years old and the electric Co-op was giving away new ones to get people to swap. Seemed like a good deal to me. Unhooked all the pipes, chimney and stuff, got it outside and carried it the 2 miles to the gulley I use for a trash dump. When I set it down by the edge of the gulley I got to thinking it might have been easier to carry if I had drained it first. So I carried it back up to the house and drained it. Then carried it back to the gulley. I was right. It WAS lighter. :eek: Got the electric one all hooked. Must have did it right because it works. Lots of hot water and no leaks, or smoke. :banana: Hahaha, that was great.
RubberDuck Posted April 2, 2013 Posted April 2, 2013 good one, Jim. i'll remember that for the next time mine goes out.
86customanche Posted April 2, 2013 Posted April 2, 2013 haha :rotf: subtle joke laid in there. clever
gogmorgo Posted April 2, 2013 Posted April 2, 2013 Don't know how much water you use, but you may find the electric tank won't heat up anywhere near as quickly as the gas one did. I have two sisters. When my parents changed out our gas tank to an electric when I was fourteen, I learned to be the first into the shower...
dasbulliwagen Posted April 2, 2013 Posted April 2, 2013 Don't know how much water you use, but you may find the electric tank won't heat up anywhere near as quickly as the gas one did. I have two sisters. When my parents changed out our gas tank to an electric when I was fourteen, I learned to be the first into the shower... I agree, recovery time on an electric is much slower than a gas. That and they don't usually last as long. DO NOT count on getting 14 years out of the new one.
JFAComanche6 Posted April 3, 2013 Posted April 3, 2013 Don't know how much water you use, but you may find the electric tank won't heat up anywhere near as quickly as the gas one did. I have two sisters. When my parents changed out our gas tank to an electric when I was fourteen, I learned to be the first into the shower... Agreed.
jimoshel Posted April 3, 2013 Author Posted April 3, 2013 In my time I've used about every method known to man to heat my water with, Not necessarily in order but , placed a bucket of cold water on a fire or stove, Electric water heater, LPG, natural gas, Kerosene, Coal stove with a water jacket, Solar. Think that covers it. Have always managed to make do with what I had. And sometimes just went 'Stinky". :eek:
Pete M Posted April 4, 2013 Posted April 4, 2013 what you should have done to move that water heater was plugged the ports and lit a fire under it. :yes:
jimoshel Posted April 4, 2013 Author Posted April 4, 2013 But how would I have controlled it's flight path? :yes: Would like to insure all my Jeeps were clear of it's impact area.
Pete M Posted April 4, 2013 Posted April 4, 2013 just angle it towards the gulley. it'll be fine. It's not rocket science. well, maybe a little bit. :yes: don't forget to film it. :popcorn:
comanchedude Posted April 5, 2013 Posted April 5, 2013 now now.. I installed new electric water heater in 1998 and its still going strong today.. just had to replace both elements once about 6 years ago.... they last fine. But i could not carry the old one filled with water... Jim is Da Man :)
