92tanMJ Posted August 1, 2013 Author Share Posted August 1, 2013 Well this is what happens when previous owner of your new tailgate switches the tailgate's hinges, rounds out the bolts and then you snap one off. :wall:Image Not FoundImage Not FoundImage Not FoundSo when you get it all fixed you celebrate..go hit some balls and have a beer with the old man. lolImage Not Found very good work....looks great! Thanks man! She is a milion times better than what she was before...everytime I look at it I smile Link to comment Share on other sites More sharing options...
87manche1 Posted August 4, 2013 Share Posted August 4, 2013 Zack looking great man way to go. Link to comment Share on other sites More sharing options...
92tanMJ Posted August 4, 2013 Author Share Posted August 4, 2013 Zack looking great man way to go. Thanks man! I'm off to go work on my rockers and change the diffs and tcase! The count down till when school starts is 3 weeks and 1 day! And then I will be driving this baby 4 hours southwest into the commonwealth of Kentucky for second year of college. (things in bold are what I would like to be done before I leave) Still left to do: -Weld in the 2x4x3/8 square stock for rockers -Change diffs & tcase fluid -retorque wheel spacers -Get new brakes front and rear -get 98+ antenna mount - may try and upgrade to a 98+ antenna cable as well becasue my reception sucks -Fix/adress SUPER slow windshield wiper motor -Fix parking brake lever (flies all the way up next to the parking break realse, covering the lever to pop the hood) Already done: -Figure out why my belt squeels like a mofo (like its not moving) (alternator was seized up) -Mild motor rebuild (for new head gasket) -Change trans fluid -Swap radio's (gotta have that HD radio!) -Change out oil pressure sender -Change out both temp readers -Recover the headliner -Swap in H4 headlights -Install new shocks all around -Install new steering stablizer -Install new bed -Install 97+ finders -Install 97+ header panel -Install 97+ mirrors - 2" hubcentric wheel spacers -New lugs all around - 2" lift spacers to level out the front some -Bondo work (needs more- probably next summer) Thread name updated to Stacy. I've been told I cannot name any of our kids Stacy, so I'll call my truck Stacy instead. & yes its because of the song. lol Link to comment Share on other sites More sharing options...
Crash Posted August 5, 2013 Share Posted August 5, 2013 Not sure if you are planning on running a CB/Ham radio etc. But I would recommend one of those firestik antenna adapters. Link to comment Share on other sites More sharing options...
92tanMJ Posted August 5, 2013 Author Share Posted August 5, 2013 Not sure if you are planning on running a CB/Ham radio etc. But I would recommend one of those firestik antenna adapters. Ive never heard of that. What does it do? Link to comment Share on other sites More sharing options...
92tanMJ Posted August 6, 2013 Author Share Posted August 6, 2013 Welded in the pass side rocker today, a little bondo and that side will be done. Changed the tcase and diffs fluid I don't think it did that much but it feels like it drives smoother and damn was that fluid nasty. :puke: Sadly I didnt get any pictures of my diffs as my hands were all oily. Image Not Found Image Not Found Image Not Found Still left to do: (bold is what I would like to get done before the 21st) -Weld in the 2x4x3/8 square stock for rockers (Pass side is done will work on drivers thursday) -retorque wheel spacers (again before I leave) -Get new brakes front and rear -get 98+ antenna mount - may try and upgrade to a 98+ antenna cable as well becasue my reception sucks -Fix/adress SUPER slow windshield wiper motor -Fix parking brake lever (flies all the way up next to the parking break realse, covering the lever to pop the hood) Already done: -Change front and rear diff fluid -Change tcase fluid -Figure out why my belt squeels like a mofo (like its not moving) (alternator was seized up) -Mild motor rebuild (for new head gasket) -Change trans fluid -Swap radio's (gotta have that HD radio!) -Change out oil pressure sender -Change out both temp readers -Recover the headliner -Swap in H4 headlights -Install new shocks all around -Install new steering stablizer -Install new bed -Install 97+ finders -Install 97+ header panel -Install 97+ mirrors - 2" hubcentric wheel spacers -New lugs all around - 2" lift spacers to level out the front some -Bondo work (needs more- probably next summer) Link to comment Share on other sites More sharing options...
92tanMJ Posted August 8, 2013 Author Share Posted August 8, 2013 I got the rockers welded on today, and I'm going camping tomorrow. It's a 2.5/ 3 hour drive so Ill let ya all know how it goes! Wish me luck! Still left to do: (bold is what I would like to get done before the 21st) -retorque wheel spacers (again before I leave for school) -Fix horn -Get new brakes front and rear -install 98+ antenna mount - may try and upgrade to a 98+ antenna cable as well becasue my reception sucks-coming in the mail and should be here the 10th -Fix/adress SUPER slow windshield wiper motor -Fix parking brake lever (flies all the way up next to the parking break realse, covering the lever to pop the hood) Already done: -Weld in the 2x4x3/8 square stock for rockers -Change front and rear diff fluid -Change tcase fluid -Figure out why my belt squeels like a mofo (like its not moving) (alternator was seized up) -Mild motor rebuild (for new head gasket) -Change trans fluid -Swap radio's (gotta have that HD radio!) -Change out oil pressure sender -Change out both temp readers -Recover the headliner -Swap in H4 headlights -Install new shocks all around -Install new steering stablizer -Install new bed -Install 97+ finders -Install 97+ header panel -Install 97+ mirrors - 2" hubcentric wheel spacers -New lugs all around - 2" lift spacers to level out the front some -Bondo work (needs more- probably next summer) Link to comment Share on other sites More sharing options...
92tanMJ Posted August 13, 2013 Author Share Posted August 13, 2013 Took the Jeep out on a two hour drive to salt fork for a little camping and skeet shooting. Image Not Found[/url] And then he wanted to snuggle... lol Image Not Found Hehehe :shake: Image Not Found Haha so we forget stuff to start our fires with so we had to use the clay's boxes...if anyone wonders 288 clays fit on the passenger side floor lol that we all shot before 9 am :rock on: Image Not Found Saw these little babies at Walmart and they would not leave my truck alone Image Not Found And I saw this on the way home Image Not Found All and all it was a good weekend, and thankfully the truck had no mechanical issues. Except for the fact that I lost my brake lights, my dash lights and my turn signals. :wall: Still left to do: (bold is what I would like to get done before the 21st) - Fix turn signals and brake lights -retorque wheel spacers (again before I leave for school) -Fix horn -Get new brakes front and rear -Fix/adress SUPER slow windshield wiper motor -Fix parking brake lever (flies all the way up next to the parking break realse, covering the lever to pop the hood) Already done: -install 98+ antenna mount with new antenna and cables -Weld in the 2x4x3/8 square stock for rockers -Change front and rear diff fluid -Change tcase fluid -Figure out why my belt squeels like a mofo (like its not moving) (alternator was seized up) -Mild motor rebuild (for new head gasket) -Change trans fluid -Swap radio's (gotta have that HD radio!) -Change out oil pressure sender -Change out both temp readers -Recover the headliner -Swap in H4 headlights -Install new shocks all around -Install new steering stablizer -Install new bed -Install 97+ finders -Install 97+ header panel -Install 97+ mirrors - 2" hubcentric wheel spacers -New lugs all around - 2" lift spacers to level out the front some -Bondo work (needs more- probably next summer) Link to comment Share on other sites More sharing options...
92tanMJ Posted August 14, 2013 Author Share Posted August 14, 2013 Got my stupid turn signals, brake lights and dash lights to work Image Not Found Image Not Found Painted my dash too, this is my before Image Not Found Here is the after shot for the dash, I used "hammered black" which has a little bit of 'texture' and I thought it matched good with fake leather print on the plastic..and IMO they do go well together. Image Not Found Still left to do: -retorque wheel spacers (again before I leave for school) -Get new brakes front and rear -Fix/adress SUPER slow windshield wiper motor -Fix parking brake lever (flies all the way up next to the parking break realse, covering the lever to pop the hood) -mount tool boxes with locks Already done: -Fix horn - Fix turn signals and brake lights -install 98+ antenna mount with new antenna and cables -Weld in the 2x4x3/8 square stock for rockers -Change front and rear diff fluid -Change tcase fluid -Figure out why my belt squeels like a mofo (like its not moving) (alternator was seized up) -Mild motor rebuild (for new head gasket) -Change trans fluid -Swap radio's (gotta have that HD radio!) -Change out oil pressure sender -Change out both temp readers -Recover the headliner -Swap in H4 headlights -Install new shocks all around -Install new steering stablizer -Install new bed -Install 97+ finders -Install 97+ header panel -Install 97+ mirrors - 2" hubcentric wheel spacers -New lugs all around - 2" lift spacers to level out the front some -Bondo work (needs more- probably next summer) Link to comment Share on other sites More sharing options...
92tanMJ Posted August 19, 2013 Author Share Posted August 19, 2013 Empty Post Link to comment Share on other sites More sharing options...
Dirteatr717 Posted August 22, 2013 Share Posted August 22, 2013 Nice work! Digging the paint! If you haven't already done this, you can take the spring out of the antenna wire in the pass side kick panel and you'll get better reception :thumbsup: the spring wears out and doesn't make a good connection on both sides and then your antenna is useless Link to comment Share on other sites More sharing options...
92tanMJ Posted August 29, 2013 Author Share Posted August 29, 2013 Nice work! Digging the paint! If you haven't already done this, you can take the spring out of the antenna wire in the pass side kick panel and you'll get better reception :thumbsup: the spring wears out and doesn't make a good connection on both sides and then your antenna is useless Thanks man, I appreciate it! Thanks for bumping me to my 4th page. lol I'm not sure where that spring would be at. I already connected my 98+ wire to the 97- that goes to the head unit.. is that where the spring is at? Link to comment Share on other sites More sharing options...
Silvergun Posted September 26, 2013 Share Posted September 26, 2013 I think i saw your cherokee on craigslist a while back?? Almost called to make an offer. I'm out in galveston, IN, but i frequent your ohio classifieds :thumbsup: Nice looking truck, I'm going a similar route, but not as far along. Will be awaiting updates! Link to comment Share on other sites More sharing options...
92tanMJ Posted September 28, 2013 Author Share Posted September 28, 2013 I think i saw your cherokee on craigslist a while back?? Almost called to make an offer. I'm out in galveston, IN, but i frequent your ohio classifieds :thumbsup: Nice looking truck, I'm going a similar route, but not as far along. Will be awaiting updates! It was lol but my parents sold their car which my brother was using...so I gave it to him. hahaha But I appreciate it man, it looks like our trucks might by twins! Link to comment Share on other sites More sharing options...
92tanMJ Posted October 11, 2013 Author Share Posted October 11, 2013 Well I went home for fall break and got sucked into help changing my brothers harmonic balancer, his bumper, his oil, and doing a tune up. lol And then I got sucked into helping my grandpa change his breaks. All in all I stilled enjoyed doing it...Better than sitting on my butt all day.Image Not FoundI also changed out the exhaust on the MJ..Still has the cat and the stock piping the only thing I did was change the muffler. Link to comment Share on other sites More sharing options...
92tanMJ Posted December 6, 2013 Author Share Posted December 6, 2013 Well as some of you my have seen I have been having some issues with keeping my motor running & I just pulled my codes and I got 12, 15, 21, 24, & 55 12- Direct battery input to PCM was disconnected within the last 50 Key-on cycles. ---normal 55-Completion of fault code display on Check Engine lamp. ---normal 15- No vehicle speed sensor signal detected during road load conditions. --- unrelated, my speedo randomly starts and stops working after it sits for a while 21- Bad 02 sensor --- I actually just ordered a new one 24-Throttle position sensor input above or below acceptable voltage. TPS signal does not correlate to MAP sensor. So here are the MAP, TPS, and 02 sensors I just ordered: MAP--- 45 bucks on amazon, 80 on quadratic. http://www.amazon.com/Crown-Automotive-33000153-MAP-Sensor/dp/B0094QJJKI TPS--- http://www.amazon.com/Liter-Throttle-Position-Sensor-Cherokee/dp/B008OOQC2O 02 -- My 98 Cheorkee loves KGN, so I'm ordering one for my MJ. http://www.amazon.com/NGK-23023-Oxygen-Sensor/dp/B000C5PY1S/ref=au_as_r?ie=UTF8&Make=Jeep|42&Model=Comanche|348&Year=1992|1992&carId=001&n=15684181&newCar=1&s=automotive&vehicleType=automotive Link to comment Share on other sites More sharing options...
92tanMJ Posted January 30, 2014 Author Share Posted January 30, 2014 Well I havent had an update in a while, Ive just been too busy. I got all the MAP, TPS, IAC, and 02 sensors changed out. No real pictures for that, its all pretty self explainitory. The 02 sensor was a pos and pia to do..I even broke the autozone tool. Took a 18" breaker bar and a bunch of heat to get it out. Image Not Found Image Not Found Then my truck died...bad battery and bad starter..the -10 below (actual temp) was pretty rough of em I guess. Image Not Found Factory starter...22 years and 200k miles. RIP little starter you lived a good life Image Not Found Got that redneck heat? Works amazingly well actually Image Not Found A picture I took for #MallCrawlinMonday #PoserStockFlex Image Not Found With working two winter jobs..well three actually...and taking a online winter term..I still found time to go hunting with the old man :yes: Image Not Found Link to comment Share on other sites More sharing options...
92tanMJ Posted January 30, 2014 Author Share Posted January 30, 2014 Still left to do: -Fix/address SUPER slow windshield wiper motor -Fix parking brake lever (flies all the way up next to the parking break realse, covering the lever to the hood pop) -Fix windsheild leak -Get new rear sliding window -Get new bumper with safty chain slots to tow boat -Drop oil pan and reallllly clean out the oil Already done: -Get new brakes -retorque wheel spacers (again) -mount tool boxes with locks -Fix horn - Fix turn signals and brake lights -install 98+ antenna mount with new antenna and cables -Weld in the 2x4x3/8 square stock for rockers -Change front and rear diff fluid -Change tcase fluid -Figure out why my belt squeels like a mofo (like its not moving) (alternator was seized up) -Mild motor rebuild (for new head gasket) -Change trans fluid -Swap radio's (gotta have that HD radio!) -Change out oil pressure sender -Change out both temp readers -Recover the headliner -Swap in H4 headlights -Install new shocks all around -Install new steering stablizer -Install new bed -Install 97+ finders -Install 97+ header panel -Install 97+ mirrors - 2" hubcentric wheel spacers -New lugs all around - 2" lift spacers to level out the front some -Bondo work (needs more- probably next summer) Link to comment Share on other sites More sharing options...
92tanMJ Posted April 6, 2014 Author Share Posted April 6, 2014 Empty Post Link to comment Share on other sites More sharing options...
92tanMJ Posted June 8, 2014 Author Share Posted June 8, 2014 Well not much to update about other than the slave in took a dumb on itself... The process itself was pretty darn easy and simple. Getting the output shaft in and out was the biggest pain of the whole thing. I can link the write ups I used if anyone is interested on that, it's veen covered enough I don't feel I need to go over it again. lol It just barely fit (with 2" backspacing) - same gap both sides I really didnt get any good pictures of it out, I was scrambling to get it all put back together since it died the weekend before I had to move 4 hours into my new apartment. Old Sachs clutch Old orginal slave..not sure why they didnt change it out at the same time..probably because the quick disconnect was broken... I could not find a transmission jack ANYWHERE locally. So I had to do what I didn't want to do and use regular foor jacks..three of them to be exact. You can also see the slave line I cut the ge the trans off and out. I had to use a angle grinder and cut the hose off after....BTW THEY DO NOT MAKE THE PLASTIC HARD LINE ANYMORE. A new slave was a 120 bucks and a new clutch kit was a 135. So that was a no brainer, it has a brand new LuK clutch in it now. Link to comment Share on other sites More sharing options...
92tanMJ Posted July 22, 2014 Author Share Posted July 22, 2014 Well folks this is the end of time being an MJ owner. I sold my truck last Wednesday and picked up that YJ Saturday. If and when it's new owner makes a build thread I will the thread here. It's bitter sweet because I have wanted a wrangler since before I could drive but I loved that truck..Gonna be one of those you always miss a little deep down inside. And my new pig.. Link to comment Share on other sites More sharing options...
Minuit Posted July 23, 2014 Share Posted July 23, 2014 Here is the new owner's thread: http://comancheclub.com/topic/43778-new-member-in-tn/ It'll be sad to see you go but I'm glad the MJ is staying in the family. He's got big plans for it and it seems like he's going to act on them pretty fast. Good luck with the YJ! Link to comment Share on other sites More sharing options...
92tanMJ Posted August 1, 2014 Author Share Posted August 1, 2014 Here is the new owner's thread: http://comancheclub.com/topic/43778-new-member-in-tn/ It'll be sad to see you go but I'm glad the MJ is staying in the family. He's got big plans for it and it seems like he's going to act on them pretty fast. Good luck with the YJ! Thank you sir, yeah he's a good guy. And thanks Ive wanted a wrangler of a while now and broke even on the manche so what the heck right? ... :( Link to comment Share on other sites More sharing options...
