  • 4 months later...
Thanks for the recomendation! Ive got the pattern for the Renix era clusters, as well as any newer ones that were swapped in. Still working on the older style with the giant fuel gauge though, going to need a full cluster fo that one.
You can see more of our work on the website or the facebook page:
www.azzysdesignworks.com
https://www.facebook.com/AzzysDesignWorks
Any questions feel free to email or post here.
For aftermarket gauges, Frank Z and I believe also John D on Naxja did a full set of autometer gauges in a custom plate of sorts setup the way the stock gauges are. I will probably go that route with my MJ.
Oh, we are launching a new style this week for all of our MJ and XJs:
I really need to change that first set, the one that is pictured above is in my XJ, and was the first set I did. The cut and form has improved since, with no crease line coming down the large faces.
I have the templates, the printer, and the cnc cutter to make what you guys want. These are not made on paper, but a special plastic film that is designed to block out any rear light and be stable in many conditions.
