jimoshel Posted March 1, 2013 Share Posted March 1, 2013 Fella just called me. Got a '88 Dakota wants to sell. 4 cylinder engine, 5 speed manual. He doesn't know a 2.5 or a AX15 from shinola. Problem is, he's to far away to just go to loook. Almost have to be sure of buying to justify the trip. My question is, what are the chance of it having the bell housing for a a AX15 swap into a '87 MJ 2.5? Link to comment Share on other sites More sharing options...
mnkyboy Posted March 1, 2013 Share Posted March 1, 2013 Its too old you want about a 98 or newer. Really unless you can find a deal on the parts its easier and not much more money to pay the $460 to buy the adapter and be done. Link to comment Share on other sites More sharing options...
Pete M Posted March 1, 2013 Share Posted March 1, 2013 98? I thought it was early 90s. :hmm: Link to comment Share on other sites More sharing options...
87manche1 Posted March 1, 2013 Share Posted March 1, 2013 Is dodge 2.5 same as jeep 2.5? Wikipedia doesn't say. Link to comment Share on other sites More sharing options...
mnkyboy Posted March 1, 2013 Share Posted March 1, 2013 96-02 were the years the AMC 2.5l was used in the Dakota. No the chrysler and AMC 2.5L are unrelated. The Chrysler is just a larger version of thier 2.2l Link to comment Share on other sites More sharing options...
87manche1 Posted March 1, 2013 Share Posted March 1, 2013 Ah learned something new ive only had the 4.0 Link to comment Share on other sites More sharing options...
jimoshel Posted March 1, 2013 Author Share Posted March 1, 2013 Yep. Anyway, saved me a wasted trip. Link to comment Share on other sites More sharing options...
88whitemanche Posted March 1, 2013 Share Posted March 1, 2013 Where do you buy the adapter kit? I've seen a few ads on Craigslist for an ax15 with out a bell housing for 150$. if I can get the bell housing, I'd go ahead and pick up the ax15 a.s.a.p!!!! Link to comment Share on other sites More sharing options...
mnkyboy Posted March 1, 2013 Share Posted March 1, 2013 Advanced adapters sells a conversion kit. Also keep in mind that an AX15 moves everything back about 2" so you will need to have your drivelines modified. Link to comment Share on other sites More sharing options...
88whitemanche Posted March 1, 2013 Share Posted March 1, 2013 Even with a lift? I mean I just want to know for future reference Link to comment Share on other sites More sharing options...
mnkyboy Posted March 1, 2013 Share Posted March 1, 2013 Its about 2" longer so it will make the front too short and the rear too long. A lift will make the front worse, it will help in the rear but you won't be able to make up the 2" so it will need shortend anyway. Link to comment Share on other sites More sharing options...
88whitemanche Posted March 1, 2013 Share Posted March 1, 2013 Ok cool Link to comment Share on other sites More sharing options...
jpnjim Posted March 1, 2013 Share Posted March 1, 2013 In CJs the 4 cyl engine mounts can be slid forward on the frame to move the engine forward. I don't have a 4cyl MJ here to look, but its worth checking out to see if the engine could be slid forward 2" or so to make the driveshafts work (yeah, it could mean some fuel line, wiring & fan shroud work to do). The other option would be to look at 6cyl driveshafts since they use that transmission. Link to comment Share on other sites More sharing options...
mnkyboy Posted March 1, 2013 Share Posted March 1, 2013 I have heard of that done on wranglers too. I haven't looked to see how hard it would be to move the engine forward on our trucks, I planned to use a 4.0l front drive shaft but I was doing a SYE so I was gonna have to make a rear drive shaft. Now I'm planning to swap a 4.3l so it doesnt matter for me anymore. Link to comment Share on other sites More sharing options...
Geonovast Posted March 1, 2013 Share Posted March 1, 2013 You also need to remember that the back of the 2.5 is a little more forward than the 4.0. 4.0 sits closer to the firewall. Not sure if that would make the AX-15 sit where it would need to or not. Link to comment Share on other sites More sharing options...
mnkyboy Posted March 1, 2013 Share Posted March 1, 2013 Its hard to say for sure, most of the information on the swap pertains to Wranglers. I just planned on doing the drive shafts so there were no suprises. Link to comment Share on other sites More sharing options...
