Speedometer
A friend borrowed my mj. Called me the next day said was not working. Checked the cable was not broke took spedometer out everything looked good. All the other gauges work. Its a 1990 2.5 ax5. thanks
Friends don't let friends drive their MJ'S. Take the speedo end of the cable. Make sure it's seated in the tranny, or TC. Try turning it with your fingers. It shouldn't turn more than a quarter turn. I made up a adapter to check speedos with. Take an old speedo cable and cut about 2 inches of the end. The end that goes into the speedo head. Chuck it up into a drill. see if the needle moves.
Put my speedometer in a 1990 cherokee and what do you know it worked. Took out of cherokee put back in 1990 comanche nothing. Pulled cable out had a kink in it so went to oreillys order new one.It was the wrong one went to autozone wrong one. I need the one with the plastic tab that goes into back off speedometer not the one with the threads. Does anyone know a part # thanks
I never could find anyone who could get the Dorman cable. Bought a NOS cable from Jackson &Sons Jeep Parts - Talladega, AL - (256) 362-7772. If 256 area code doesn't work, try 205, but pretty sure it's 256.
I'd tell you how much I paid for it, but I'd have to dig through the whole file folder and then I'd realize how much money I've spent on the truck and get really PO'd at myself. It was reasonably priced and available. Also bought a NOS exhaust manifold from him for $125.
oreillys was a nightmare.It was a special order part no big deal got part 2 days later.Wrong part had to fight with them just to get refund minus s&h ($7.00). They said they would order another cable. Another special order no thanks. It has being a nightmare
