HOrnbrod Posted October 30, 2012 Share Posted October 30, 2012 I went to change the CPS today because my truck sometimes has the classic symptom and cranking and not starting when warm. Got out about 1/2 mile of extensions with a univesal on the end and proceeded to remove the two 11mm bolts from underneath. The bolts were very tight and when applying torque, the socket slipped off the universal and disappeared. I didn't hear it land anywhere. Spent about thirty minutes dragging a magnet wand all around the area with no joy. Then I looked up there, and saw there was a cutout right under one of the CPS sensor bolts in the AW4 bell housing. Aw s%*t! Stuck the magnet as deep into the bell housing hole as it could go, again no joy. I removed the flexplate inspection cover hoping it fell through, the third no joy. Thoroughly POed at this point, I started the engine, immediately heard a brief little clink, then shut it off. The socket was laying on the floor. It came out of the bell housing where the inspection plate was mounted. No damage, no problem. Moral of story: Stuff a rag in that bell housing cutout hole near where the CPS is mounted BEFORE trying to change the CPS. Link to comment Share on other sites More sharing options...
Geonovast Posted October 30, 2012 Share Posted October 30, 2012 I take it you lost the little plastic piece that normally occupies that hole? Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 30, 2012 Author Share Posted October 30, 2012 I take it you lost the little plastic piece that normally occupies that hole? Really? There's never been one there. Got a pic? Link to comment Share on other sites More sharing options...
Geonovast Posted October 30, 2012 Share Posted October 30, 2012 I know the last 88 XJ I had had one, fairly certain the 99's got it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 30, 2012 Author Share Posted October 30, 2012 Thanks. Just saw that on Gojeep's site. And no, I do not have one on the tranny. I can't find it in my parts manual either. Any suggestions as to where I could find one or order one? Link to comment Share on other sites More sharing options...
Geonovast Posted October 30, 2012 Share Posted October 30, 2012 No clue, it was hard enough just to find a picture of one. Link to comment Share on other sites More sharing options...
Alexia Posted October 30, 2012 Share Posted October 30, 2012 Thanks. Just saw that on Gojeep's site. And no, I do not have one on the tranny. I can't find it in my parts manual either. Any suggestions as to where I could find one or order one? This is for the AW4. MOPAR 52117660 - GROMMET, Timing Probe $3.30 from the dealership if they have it in stock. Page 490 of the combined 1997, 1998, 1999 XJ parts manual, #27 on the diagram. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 31, 2012 Author Share Posted October 31, 2012 Thanks Alexia. Now that you provided the part number, I found it in my 91-93 parts manual. Weird though, here's what it says: 53005129, 1, GROMMET, 1991 and below 52117660, 1, GROMMET, 1992 and up Weird. It appears the part number changed in 1992. :hmm: Well, I'll find one - many thanks! Link to comment Share on other sites More sharing options...
Alexia Posted October 31, 2012 Share Posted October 31, 2012 Probably a slightly different cut out. I freaked out a bit when I lost mine while cleaning the transmission! Link to comment Share on other sites More sharing options...
Geonovast Posted October 31, 2012 Share Posted October 31, 2012 1991 does have its own plug for the CPS, maybe they slightly changed the shape for the new plug in 92. Link to comment Share on other sites More sharing options...
mountainman Posted October 31, 2012 Share Posted October 31, 2012 that could have gotten UUUUUgLYY Link to comment Share on other sites More sharing options...
flint54 Posted October 31, 2012 Share Posted October 31, 2012 Oh man, you dodged a big bullet !! Hope you find one. A quick search of ChryCo shows NLA. I bought one from Morris 4x4 a year ago, but they no longer carry them. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 31, 2012 Author Share Posted October 31, 2012 Oh man, you dodged a big bullet !! Hope you find one. A quick search of ChryCo shows NLA. I bought one from Morris 4x4 a year ago, but they no longer carry them. Oconee Offroad has them, $4.10 shipped. :yes: says it'll fit the 91s, we'll see. Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 31, 2012 Share Posted October 31, 2012 Funny, I just replaced the CPS in the'89 on Saturday, I was being extremely carefully but dropped the top bolt into the bellhousing. Same as you Don, magnetic pick up tool didn't work but when I unbolted the inspection plate I found the bolt at the bottom of the housing, very happy. My grommet is also missing, thanks for the availabiliy info. Link to comment Share on other sites More sharing options...
1987Comanche Posted October 31, 2012 Share Posted October 31, 2012 The Renix CPS is a direct plug and play for a later model HO AX-15 bellhousing, correct? No weird spacing changes, etc? Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 31, 2012 Author Share Posted October 31, 2012 Funny, I just replaced the CPS in the'89 on Saturday, I was being extremely carefully but dropped the top bolt into the bellhousing. Same as you Don, magnetic pick up tool didn't work but when I unbolted the inspection plate I found the bolt at the bottom of the housing, very happy. My grommet is also missing, thanks for the availabiliy info. Will let you know if the grommet fits Mike. I see conflicting reports, but for a little over $4 it's worth a shot. The Renix CPS is a direct plug and play for a later model HO AX-15 bellhousing, correct? No weird spacing changes, etc? I doubt it. But without an exact model/year I'm not guessing. Getting tired of that. Link to comment Share on other sites More sharing options...
Geonovast Posted October 31, 2012 Share Posted October 31, 2012 All the CPSs will mount to any of the bellhousings just fine. Just remember that the CPS has to stay with the control system, regardless of year of the transmission. Link to comment Share on other sites More sharing options...
shelbyluvv Posted October 31, 2012 Share Posted October 31, 2012 We have a HMMWV (Hummer H1) in the shop with a perfect hole in the bell housing from a bolt that was shot into from the flex plate! Link to comment Share on other sites More sharing options...
mountainman Posted November 1, 2012 Share Posted November 1, 2012 We have a HMMWV (Hummer H1) in the shop with a perfect hole in the bell housing from a bolt that was shot into from the flex plate! yup. Turn the motor over by hand if you drop one in, do NOT start it. Mucho badness can happen and you WILL cry. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 15, 2013 Author Share Posted January 15, 2013 Thanks Alexia. Now that you provided the part number, I found it in my 91-93 parts manual. Weird though, here's what it says: 53005129, 1, GROMMET, 1991 and below 52117660, 1, GROMMET, 1992 and up Weird. It appears the part number changed in 1992. :hmm: Well, I'll find one - many thanks! EDIT: The p/n 52117660 GROMMET does NOT fit the 91 and below AW4 CPS cutout. Do not order. If anyone has the CPS grommet (plastic cover) for a 91 or Renix AW4 lying around, sure would appreciate one. Link to comment Share on other sites More sharing options...
