oldskool023 Posted October 23, 2012 Posted October 23, 2012 Ok well i have been searching through different sites google jeep forumes etc.. i ran into a problem last week with my rig while i was offroading. this is antidisestablishmentarianism happened i was going up a steep hill in 4 low in 1st gear about to shift into 2nd but as soon as i gave it gas 1 more time a load pop underneath my truck like if i blew the motor so i slowly came down in reverse and park it and let it cool off for a bit. antidisestablishmentarianism came to mind was my cat was clogged so i unbolt and nothing same sputter.....so I take it back to the shop to look more into it i replace the cap, rotor, sparkplugs and still the same thing this i check the injectors all function, 45 pds at the rail. so then i decide to do a compression test and it was 135 across on a 200k motor so not bad i replaced the distribitor nothing then the cps and the same so tommorrow I'm gonna replace the wires and keep checkin the truck, so after all this the truck turns on and sputters to the point where i can't drive it. i need and want my truck so i really need ur help antidisestablishmentarianism it can be. 1. spark plug wires 2.check for loose grounds 3.next to do is check the timming chain replace if needed 4.? 5.? S.O.S has anyone gone through this ??
oldskool023 Posted October 23, 2012 Author Posted October 23, 2012 Also my truck is a 1987 jeep comanche 4.0 5spd with 200k
ParadiseMJ Posted October 23, 2012 Posted October 23, 2012 antidisestablishmentarianism So, for any of you readers... antidisestablishmentarianism = what, WTF, WTH OP, your post is messed up, hard to read. Edit and/or re-post. No one can tell antidisestablishmentarianism is wrong with your Jeep if they can't read the post. Antidisestablishmentarianism is this world coming to??
oldskool023 Posted October 24, 2012 Author Posted October 24, 2012 @ paradisemj i honestly do not know what that was there was a glitch i guess & mjcarena thats antidisestablishmentarianism I'm thinking but ill tear it apart on thursday and try to check it out
87Chief Posted October 25, 2012 Posted October 25, 2012 I think that's a automated word.. unless you really meant that..
jimoshel Posted October 25, 2012 Posted October 25, 2012 Personally I'm a big fan of the word "Preantidisestablishmentarism".
Geonovast Posted October 25, 2012 Posted October 25, 2012 w a t automatically changes to antidisestablishmentarianism, because people leaving out the 'h' in what is one of the most annoying things people do when typing.
88mjgilley Posted October 27, 2012 Posted October 27, 2012 Check the crank sensor my old 88 had bad motor mounts and climbing a hill once when the motor came up the cps met the firewall and snapped it
JFAComanche6 Posted October 27, 2012 Posted October 27, 2012 I would check for a fuel problem, my MJ acts up sometimes when I take hills and I'm sure I'm running rich on fuel. It just doesn't bother me enough to troubleshoot it yet ha
oldskool023 Posted October 29, 2012 Author Posted October 29, 2012 well i replaced the dizzy and the cps but I'm almost done replacing the timming chain
oldskool023 Posted November 8, 2012 Author Posted November 8, 2012 well so far i replaced the timming chain and just found out my dizzy is bad but i think its the ecu help me please
88elimnator Posted November 9, 2012 Posted November 9, 2012 check the ceramic block on the driver side inner fender, I can't remember what it was called but that damn thing caused me all kinds of grief. It sputtered real bad and sometimes would'nt even start, chanched that block and it was all better. Quick way to check is to pull the two wires going to it and connect them together. if the sputtering stops then replace that evil block.
JFAComanche6 Posted November 13, 2012 Posted November 13, 2012 Its the ballast resistor (I don't mean to harass 88eliminator, ha) and its kinda shaped like the alamo.
ftpiercecracker1 Posted November 13, 2012 Posted November 13, 2012 On the driver side of the engine bay.
