Yup, it's a 1-wire deal in the exhaust manifold, and my guess is it inputs to the computer which controls a solenoid on the side of the carb.
You need a digital meter. A analog won't hack it. With the engine off back probe the O2sensor lead. Turn the key on. Meter should read .45volts. Here I've noticed sometimes it will and sometimes it won't. Start engine. after engine has warmed up the voltage should vary between .2 and .75 volts, It is necessary to rev the engine several times while checking voltage. Just idling won't get it.
  • 2 months later...
Okay, finally got a chance to check the reading from the 02 sensor, and here's what I came up with. All readings are taken with the digital multimeter grounded to the battery terminal, positive probe contacting the harness side of the plug (not the sensor side of the plug) with everything hooked up/plugged in.
Engine off, key on: .09V
Engine idling: .90V
Engine held around 2,000-2,200 RPM?: Slowly falls from .90V to .50V or less.
Verdict?
Carter YFA, if I'm not mistaken; it's some variation of a YF. Oh, yeah - reading the O2's output is the first thing I've done on it. I'm just optomistic that a new sensor will fix it, and I won't have to dive into the maze of wires and vacuum lines surrounding the carb. :D
