1988 Jeep Comanche Aka The Penny Sniffer ,pic Heavy
After installing the Driver mount I will tell you on the renix engine it is not a direct bolt on you will have to modify the driver bracket. you will need a 5 inch cut off disk or grinding disk on a cut off wheel, to remove the access metal that keeps the Iron man mounts from sliding in. It is quite a task but I promise you once it is done it is time and money well spent!
So here were my problems withe the pace setter header hardware...... It sucks all of the "step washers were off set and did not fit right, so I had to special order a new set of the and then had to hand grind them to fit.....
So with the pacesetter Header I had to plug the EGR and I did it by making a plate for it on the intake, also the is a tube that runs from the bottom of the intake to the old manifold I made a plug for that bud did not get pictures.
