87 ghost Posted July 2, 2012 Share Posted July 2, 2012 What yr bucket seats from a xj will fit in 87 mj ? Gotta get rid of the bench Link to comment Share on other sites More sharing options...
Pete M Posted July 2, 2012 Share Posted July 2, 2012 through 95. but avoid seats with the curved track unless you're short (they raise you up a few inches). and only 2-door XJs have seats that fold forward. :thumbsup: Link to comment Share on other sites More sharing options...
87 ghost Posted July 2, 2012 Author Share Posted July 2, 2012 Thanks, for the info Link to comment Share on other sites More sharing options...
Pete M Posted July 2, 2012 Share Posted July 2, 2012 and you'll be re-using your bench's floor brackets. Link to comment Share on other sites More sharing options...
87 ghost Posted July 2, 2012 Author Share Posted July 2, 2012 Ten foe thanks again Link to comment Share on other sites More sharing options...
Pete M Posted July 2, 2012 Share Posted July 2, 2012 oh, and you might want to snag the female ends of the seatbelts too. buckets have a sleeve that holds them up so they don't keep falling to the floor. hopefully that's all the tips this time... :rotf: Link to comment Share on other sites More sharing options...
Stacks Posted July 2, 2012 Share Posted July 2, 2012 Uh huh...... now he says something about the sleeve!!!! :roll: Thanks Pete! :D Link to comment Share on other sites More sharing options...
aaronbtxnc Posted July 5, 2012 Share Posted July 5, 2012 Also get the console and the rear mounting brackets for it, it works without the rear brackets but it's kinda wobbly. When getting the console also get the black vent adapter thingy (routes air to floorboards and through to back seat in XJ) that it's attached to or nested in. Link to comment Share on other sites More sharing options...
Zenobian_84 Posted July 25, 2012 Share Posted July 25, 2012 through 95. but avoid seats with the curved track unless you're short (they raise you up a few inches). and only 2-door XJs have seats that fold forward. :thumbsup: Sorry to dredge this thread back up, but I've never heard of the "Curved Track" before. Been thinking a lot of converting over to some decent buckets. Pic of curved track? :dunno: Not sure what the difference is here (aside from what Pete mentioned). I'm about 6'4, so this would be a bit of a problem. :yes: EDIT: Nevermind. Solved my own question with a bit of searching. :doh: Link to comment Share on other sites More sharing options...
Pete M Posted July 25, 2012 Share Posted July 25, 2012 I would still buy a good set of curved-track seats, but I wouldn't install them without the straight tracks from another jeep. Link to comment Share on other sites More sharing options...
Geonovast Posted July 25, 2012 Share Posted July 25, 2012 I'm 6'1", and have the curved brackets in one of my MJs. If I'm first in line at a stop light, I have to lean forward to see the light. :headpop: Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 26, 2012 Share Posted July 26, 2012 through 95. but avoid seats with the curved track unless you're short (they raise you up a few inches). and only 2-door XJs have seats that fold forward. :thumbsup: Actually the 1993 and below XJ seats are bolt-in for the MJs. The seats were redesigned in 1994 so using these in an MJ involves more work. Can be done of course but not bolt-in. Link to comment Share on other sites More sharing options...
Pete M Posted July 26, 2012 Share Posted July 26, 2012 94 then :thumbsup: Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 26, 2012 Share Posted July 26, 2012 94 then :thumbsup: We're picky-picky even now Pete. :D Link to comment Share on other sites More sharing options...
mvusse Posted July 26, 2012 Share Posted July 26, 2012 My old 94 had the same seats as my buddy's 90. My 96 has the same seat brackets as the later body style ones (and possibly the same as ZJ as well). Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 26, 2012 Share Posted July 26, 2012 I suppose it's possible some of the 93 seats made it into the 94s, like a lot of things Jeep carried over. If your 96 has the same seat brackets as the 93 (or 94), I don't see how they were bolted to the 96 floor w/o mods because the bolt pattern was completely different. Link to comment Share on other sites More sharing options...
mvusse Posted July 26, 2012 Share Posted July 26, 2012 The 94 seats bolted straight down. Actually, IIRC there were studs in the floor and the seat just used nuts. The 96 seats bolt front to back to a bulkhead on top of the floor in the front, and straight down into the floor in back. I think they are Torx bolts, but not sure of that and the vehicle is 20 miles away at the moment. Link to comment Share on other sites More sharing options...
jamespwsullivan Posted July 26, 2012 Share Posted July 26, 2012 OK. I think I'm following this. I'm looking at some replacement seats from omix-ada (http://www.driveoffroad.com/rugged-ridge-13446-37/) that are supposed to be adaptable to 84-96 XJs. They come with some different bracket pieces but not true adapter plates. If you're interested download the installation manual and look at the last page. Of course, I'm wondering if they can be put in my MJ which has horrible bucket seats. So I removed the MJ passenger seat and took off the bracket. So far so good. I compared it to the drawings that have been posted a bunch of times (early in this thread for example) and they look like a match. What is confusing to me is that my 96 XJ brackets are not at all like the ones in that drawing. Now I can understand that these replacement seats could fit a bunch of different configurations of bracket since they come with hardware designed to adapt them. Based on what I've read in this thread I'm thinking there is another style of XJ bracket that is not shown in the drawings? I just don't see one that looks like the one in my 96. (four door no power no heat) If you can understand my ramblings this far you're doing well. My actual question is this... On the seat bracket drawings, what is the difference between the XJ bracket (labeled 'straight') and the MJ bracket (labeled 'bucket')? And are the two examples of each of those supposed to be the same or are they different depending on the side of the vehicle? I'll get these trucks figured out some day...maybe Link to comment Share on other sites More sharing options...
Pete M Posted July 27, 2012 Share Posted July 27, 2012 The XJ straight and MJ buckets have the same straight sliding track parts. the only difference is the floor brackets (MJs and XJ have very different floorpans under the seats). Link to comment Share on other sites More sharing options...
jamespwsullivan Posted July 27, 2012 Share Posted July 27, 2012 Thanks Pete. that does answer my question. I'll post a few pics of the Rugged Ridge seat installation when I get it done. It should go smoothly... Ha! Link to comment Share on other sites More sharing options...
