whats causing it? its really bad on the passenger side. i don't see any adjustments for camber so that leads me to believe its balljoints. any ideas?
How bad is it? Just happen?
Factory had some pooely jigged front axles about that time. The right side would have excessive negative camber. Solution was adjustable ball joints.
yeah its on the passenger side. negative camber. makes the front look like one of those stanced honda civics. can i fix it without replacing the axle?
adjustable ball joints can only fix a small amount. if you can notice the problem with the naked eye, I have a feeling they won't tweak it far enough.
well the axles seals leak so might as well go get a new d30 and swap the shafts out with my new rejointed ones. the problem is finding an axle with 4.10s
