AMC-MJ Posted May 21, 2012 Posted May 21, 2012 Can I use DOT 3 synthetic fluid, like I did in the brake system in this truck? Mike
AMC-MJ Posted May 22, 2012 Author Posted May 22, 2012 OK. I used it in the brakes, and have some left over. And, I was going to use it in the clutch, so I don't have to buy more fluid. LOL! Yep, I'm a cheapskate! Mike
Blue88Comanche Posted May 24, 2012 Posted May 24, 2012 the cap on my original clutch said to use DOT 3 only. however if it leaks "and it will" it will drip onto your fuse box and cause problems. you can flush it out and use DOT 5. at least then if it leaks onto the fuse box nothing melts
AMC-MJ Posted May 24, 2012 Author Posted May 24, 2012 It is going into a whole new clutch system. Replacing it all! Not going to put it in the old one. Mike
cruiser54 Posted May 25, 2012 Posted May 25, 2012 Are you replacing the hose between the master and slave?
Blue88Comanche Posted May 26, 2012 Posted May 26, 2012 It is going into a whole new clutch system. Replacing it all! Not going to put it in the old one. Mike in that case it you are replanting everything then use dot 5
cruiser54 Posted May 26, 2012 Posted May 26, 2012 The factory had issues with the original hose between the cylinders until 1991 IIRC. They were made for Castrol GT LMA as the cylinders were British. Even with the correct fluid, and worse if not, the inside of the hose deteriorated and introduced a white abrasive crap into the system. So, you could replace a leaking master and soon after you were replacing the slave, but then the new master didn't last long. Factory solution was to replace master, slave, and hose all at the same time. IIRC, the factory switch suppliers later on for replacement cylinders to Japanese which were fine.
AMC-MJ Posted May 26, 2012 Author Posted May 26, 2012 The whole clutch system will be brand new! It is sitting here, waiting, on the bench. Clutch master and slave cylinder, line in-between, throw-out bearing, and clutch disk. Any bolts, screws, gaskets, and seals will also be replaced, as needed. I've got a little under a quart of Prestone DOT 3 synthetic fluid left. Will that be enough, or should I just order the Amsoil now? Mike
Eagle Posted May 29, 2012 Posted May 29, 2012 I've got a little under a quart of Prestone DOT 3 synthetic fluid left. Will that be enough, or should I just order the Amsoil now? Skip the Amsoil. Use DOT-5 silicone and stop worrying. It's non-corrosive and non-hygroscopic. And IF the master cylinder ever leaks, it won't eat up the fuse panel if it drips on it.
AMC-MJ Posted May 29, 2012 Author Posted May 29, 2012 :eek: you got to replace that too :ack: Yes the kit came with a pressure plate, throw-out bearing, clutch disc, master cylinder, and slave cylinder :D Silliest looking slave I have ever seen, looks like a brake caliper piston assembly ! I might get around to installing this clutch kit one day ! ! I have some prestone DOT3 synthetic left over from when I did the whole brake system 4yrs ago so that's what it'll get for fluid unless 2/3Qt isn't enough than I will order up some amsoil brake fluid . . . If I gotta buy fluid I buy amsoil ;) I bet once I switch over the AX-15 will require a whole new hydro system too ! ? ! ? ! Mike
Blue88Comanche Posted May 29, 2012 Posted May 29, 2012 I have some prestone DOT3 synthetic left over from when I did the whole brake system 4yrs ago so that's what it'll get for fluid unless 2/3Qt isn't enough than I will order up some amsoil brake fluid . . . If I gotta buy fluid I buy amsoil ;) Mike from what i have been told dot 3 fluid can go bad IF moisture gets to it, opened, used, then stored for years, and so on. but that's what i have been told and I haven't bought a large container in a while just small ones. next time i replace something dealing with the clutch i am swapping to dot 5 for sure I bet once I switch over the AX-15 will require a whole new hydro system too ! ? ! ? ! Mike I used the same hydro system for my AX-15, just a new slave clutch cyl.
AMC-MJ Posted May 29, 2012 Author Posted May 29, 2012 Its synthetic, I was under the impression that it didn't break down. Well I been using it to limp the dying system along so I may as well just get some new fluid than and play it safe I guess. I really was hoping NOT to invest any more into this power train so much for that eh ? All I wanna do is get my AMC-V8 swap done :wrench: but something always comes up on me job lose due to down sizing, unforeseen bills or expense. Such is life I guess I ain't giving up tho ;) Mike
carnuck Posted June 7, 2012 Posted June 7, 2012 When mine started leaking at the slave, since I was going to auto anyways, I filled it with cooking corn oil and got another year out of it.
AMC-MJ Posted June 7, 2012 Author Posted June 7, 2012 Full of fluid and blead out I only get 3 runs through the gears and its out of fluid, it is no longer driveable I have been without wheels for a while now. Mike
carnuck Posted June 7, 2012 Posted June 7, 2012 That's why I did the corn oil/crisco cooking oil in instead of brake fluid
AMC-MJ Posted June 7, 2012 Author Posted June 7, 2012 Ya well filling it 3 times per round trip to work and back just isn't worth while. Mike
carnuck Posted June 7, 2012 Posted June 7, 2012 After the second fill with Crisco, it didn't need anymore till the pilot seized up
AMC-MJ Posted June 8, 2012 Author Posted June 8, 2012 I bought all the parts to fix it, going to install them and drive on ;) Mike
AMC-MJ Posted June 16, 2012 Author Posted June 16, 2012 Amsoil only carries DOT 3 and DOT 4. The local stores only carry DOT 3 and DOT 4 in the large containers. O'Riely's carries DOT 5 but only in small containers. So, I purchased 2 little bottles, that's all they had. According to the store manager, there is not much of a calling for DOT 5. Is 22 ounces going to be enough? Now Weaver Auto Parts says they have a product called DOT 5.1. What's this? While snooping around another parts store, I think it was Car Quest, I found a product in a similar bottle to brake fluid, called Hydro Clutch Fluid, apical to all hydro clutching systems. Anybody use this? Mike
carnuck Posted July 19, 2012 Posted July 19, 2012 I would read the bottle to make sure that's not for wet clutches.
AMC-MJ Posted July 19, 2012 Author Posted July 19, 2012 I bought the DOT-5, Anywho trucks long been fixed almost got 1000 miles on the new clutch system ;) Mike
