JeepcoMJ Posted June 6, 2007 Author Share Posted June 6, 2007 lol, i succeeded. it's a convenience for now, and since this truck is a sorta clean one that isn't wheeled, i don't really wanna make a tire carrier for it in the bed (if i even had time to do it anyways...if I'm not at work, I'm on here because the day's spent or i'm on my break). Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 7, 2007 Author Share Posted July 7, 2007 new front axle on it's way. hi-pinion out of a 98 xj, non-disco, 3.73 gears to match my 3.73 ford 8.8 rear axle. Link to comment Share on other sites More sharing options...
ejndssn Posted July 9, 2007 Share Posted July 9, 2007 was it a bear to get that spare carrier down or PB the bolts to death then make the attempt :dunno: I'm leanning to the PB to death prior to attempt get at the bolts :brows: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 10, 2007 Author Share Posted July 10, 2007 took me about 3 minutes. this thing is a rust-free truck, soooo yeah things like that aren't a problem for me :P Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 28, 2007 Author Share Posted July 28, 2007 well this has taken a back seat to the 89...temporarily. plans for september are to remove the dash, and heater assembly, replace with black dash and a/c box, put in a black steering column. It needs a new trackbar (oh, got one from the 89 left over :P), and new UCA bushings. sadly because of the camaro motor and my exhaust manifolds, I have to remove the exhaust to get the bolts out...unless I torch the bolts, which might not be a bad idea come to think of it... then the 8.8 will be ready to go in. going with the one with 3.55 gears for now, since I don't want to change gears on this truck, just drive it with all wheel discs. and I have to repaint the entire bottom edge (both sides) as this one is rusting Link to comment Share on other sites More sharing options...
mfpdm Posted July 28, 2007 Share Posted July 28, 2007 plans for september are to remove the dash, and heater assembly, replace with black dash and a/c box, put in a black steering column. Thought about ya at the JY today when I came across a black steering column and wheel. I also found a D44 in an XJ but the guy wanted more than twice the price of my regular pick and pull. It was $250 which wasn't too bad but if I'm patient, I'll have one for cheaper. Didn't dare ask how much for the wheel. Hope you got one already. :cheers: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 29, 2007 Author Share Posted July 29, 2007 plans for september are to remove the dash, and heater assembly, replace with black dash and a/c box, put in a black steering column. Thought about ya at the JY today when I came across a black steering column and wheel. I also found a D44 in an XJ but the guy wanted more than twice the price of my regular pick and pull. It was $250 which wasn't too bad but if I'm patient, I'll have one for cheaper. Didn't dare ask how much for the wheel. Hope you got one already. :cheers: doncha hate them high prices? yep, got a black column (have to swap cruise stalk into it), and a nice leather wrapped black steering wheel. all I need is the black horn button with the hex heads now...so if ya find one of them, pocket it! Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 2, 2007 Author Share Posted August 2, 2007 removed the coolant reservoir from it today and installed one from a 92 comanche. then I have to remove the coolant reservoir and put one in it from a 87 cherokee. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 2, 2007 Author Share Posted August 2, 2007 oh, the point of this part of the project is to move the air intake from below the radiator to the side which will allow a cooler intake and I won't hydrolock it. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 24, 2007 Author Share Posted August 24, 2007 well, a 97+ wiper reservoir will be installed soon. this winter, I'm replacing the driver's side cab corner (rusting through worse than I thought...I'm NOT happy with the guy who did the paint and finishing body work right now. I also hope to remove the valve covers and upper intake to repaint them...they got slightly scratched up during the install. I also have to alter the driver's side exhaust manifold because it's too close to the frame rail for my comfort (it's quite possible that it's been heating up the UCA bushing). getting a non-cad front axle with 297's that's not bent (unlike my current one :P) on saturday morning, along with a chryco 8.25 and they're both 3.55 gearing with 100,000 miles on them. they'll both be installed, and I may upgrade to an 8.8 at a later date...and regearing to 3.73's up front. the axle deal may be happening within the next few weeks, my current axle is fubar it's thrown off all the alignment etc from having the left C bent inwards. needs new UCA bushings as well so the upgrade may as well happen all in one go. I'll also be purchasing a new black carpet and removing the black rubber matt...I will be running completely waterproof insulation so that the moisture doesn't hold and rust the floor. Link to comment Share on other sites More sharing options...
89eliminator Posted August 24, 2007 Share Posted August 24, 2007 rusting already!! yikes!! i would be pissed to if that happened to my truck too. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 24, 2007 Author Share Posted August 24, 2007 rusting already!! yikes!! i would be pissed to if that happened to my truck too. yea, come take a look at my driver's side cab corner, and my driver's side rear quarter...paint FELL OFF right in front of the bumper. i don't mean cracked, I mean a 50 cent piece sized section of paint completely fell off. so guys, if you're local to me, find a better place than I did. the paintjob cost me $1800 and in less than 3 years, it's rusting. how $#!&ty is that? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 28, 2007 Author Share Posted September 28, 2007 well, got a new front axle for it, a 1994 dana 30 with 3.55's and normal 260 joints. but it's in good shape, not bent, good hub bearings, and no CAD to speak of (thank god). also tore the ax5 outta tater before I scrapped it, so I have a good tranny and t-case to replace my worn out one (bad bearings and syncros on 1-3 gears lol). it got hit in the back of the bed, so at the very least I gotta clean up the problem area and bend it back and primer it...I'm not driving it this winter anyways. also have an xj 8.25 rear axle from the 94 xj. not sure on spline count, and I don't really think I wanna install it...unless I can get a disc brake kit for it for cheap. it's low pinion. i don't like that. and I would like to lift it and put the 33's I have under it. Link to comment Share on other sites More sharing options...
Twisty Posted September 28, 2007 Share Posted September 28, 2007 If its a 1994 then its 27 spline. Not worth the swap. ;) Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 28, 2007 Author Share Posted September 28, 2007 10-4. maybe I can find some sucker to buy it. I only payed $100 for both axles, complete with ebrake system and all the steering/control arms and such as well. Link to comment Share on other sites More sharing options...
89eliminator Posted September 28, 2007 Share Posted September 28, 2007 by the way Pat, the Jefferson swap meet is this weekend. i am going Sunday. thought i would tell you just in case you needed to buy something. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 28, 2007 Author Share Posted September 28, 2007 by the way Pat, the Jefferson swap meet is this weekend. i am going Sunday. thought i would tell you just in case you needed to buy something. thanks wade, I just found that out today...I'm going to platteville this weekend, but I think my bro and I are gonna crash at my apartment 2nite, go in the morning, and head up to platteville via madison after that at about 2 or so... thanks though! oh, the grinding in the tranny is TERRIBLE now...I'm gonna try swapping fluid tonite to see if that will help for now. also, I'm putting a "new" wheel bearing on the front left side since that's the problem side....I just don't have time to actually replace anything major right now. the xj has gotta be done first so I can park this POS. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 28, 2007 Author Share Posted September 28, 2007 ....it blew. no work on yankin motor now this weekend, gotta prep the new tranny 2nite, go see the sis til sunday, and install the new tranny sunday nite. sucks. Link to comment Share on other sites More sharing options...
Oizarod115 Posted September 29, 2007 Share Posted September 29, 2007 ....it blew. no work on yankin motor now this weekend, gotta prep the new tranny 2nite, go see the sis til sunday, and install the new tranny sunday nite. sucks. my puke-goat has been grinding when i go to shift but only if I'm gettin on it, like if i slam a shift at 4,500 it'll grind a slight bit ont he way in, and then if i downshift from 5th to 4th without revvin it up a tiny bit, or movin up towards 3rd then puttin it back to 4th, like swing almost into 3rd then hit 4th it won't grind but if i just downshift to 4th itll grind sound anything like what yours was doin before it took the poop? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 29, 2007 Author Share Posted September 29, 2007 yup, but now I can still shift....sometimes. before the bearings bind up. and then the gears move around or something and it just lets loose and grinds like a mother. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 1, 2007 Author Share Posted October 1, 2007 it was the secondary shaft front bearing or w/e. I put the new tranny in, with help from my dad. also my rear ujoint on the main d-shaft was bad so he replaced that. it works, 4wd actuator doesn't due to a bad vac. switch on the t-case. Link to comment Share on other sites More sharing options...
89eliminator Posted October 1, 2007 Share Posted October 1, 2007 did you buy anything at Jefferson? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 1, 2007 Author Share Posted October 1, 2007 I didn't go. got a wicked cool purple rollbar in beloit at a garage sale though... outta a yoter...needs to be a bit higher and alter the rear support thingies to fit in my truck :D Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 1, 2007 Author Share Posted October 1, 2007 here's the rundown on tranny removal...what a b*tch with the 3800 and my exhaust manifolds... 1. remove rear d.s. 2. remove speedo cable. 3. support tranny with a stand. 6. disconnect exhaust support 7. drop tranny crossmember 8. unbolt front driveshaft entirely 9. disconnect shift linkage. 10. disconnect y-pipe from manifold disco o2 sensor and knock sensor, move wires, disconnect ALL of the exhaust supports, and either slide the exhaust out the side of the truck, leaving it hang over the axle, or remove it entirely. 11. under hood...remove pass. side exhaust manifold entirely. it's in the way of the bellhousing on the back end. disco o2 sensor 12. remove center console, floor seal, shifter. 13. remove dust shield 14. support tranny with jack, lower it down. 15. unbolt bellhousing from engine block. 16. slide tranny back, down, and out. install is in exact reverse. I hate that exhaust manifold. it adds alot of extra work...I should rebuild the lower portion of it. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted October 6, 2007 Author Share Posted October 6, 2007 'nother pic of the rollbar to be modded and installed Link to comment Share on other sites More sharing options...
