BARILLMS Posted February 10, 2007 Posted February 10, 2007 How long is a stock MJ leaf eye to eye? Anyone know how long these other leafs are? XJ rear leaf? YJ rear leaf? Full size waggy rear leaf? How wide are MJ and XJ leafs?? 2.5" ?? Is that right? thanks
DirtyComanche Posted February 10, 2007 Posted February 10, 2007 Pete has a thread where he compared them to exploder leafs. http://comancheclub.com/forums/viewtopi ... s+explorer I think it says in there.
minydigger Posted February 10, 2007 Posted February 10, 2007 MJ springs are 26" from eye to center pin and 31" from center pin to rear eye so a total of 57". Full size waggy rears are the same dimensions as the MJ just flatter. Not to sure on XJ and YJ. I am picking up a set of rear waggy's to put on the back of my MJ to level it out some. And they are 2.5" wide
DansGreyMj Posted February 11, 2007 Posted February 11, 2007 MJ springs are 26" from eye to center pin and 31" from center pin to rear eye so a total of 57". Full size waggy rears are the same dimensions as the MJ just flatter. Not to sure on XJ and YJ. I am picking up a set of rear waggy's to put on the back of my MJ to level it out some. And they are 2.5" wide do the waggy leavs bolt right in if so how much lift do they give soa
minydigger Posted February 11, 2007 Posted February 11, 2007 They will bolt right up. I am not sure on the lift, as I went soa with stock 4wd springs and it is to much lift for the setup I have in the front. I will let you know tomorrow after I put them in.
DansGreyMj Posted February 11, 2007 Posted February 11, 2007 They will bolt right up. I am not sure on the lift, as I went soa with stock 4wd springs and it is to much lift for the setup I have in the front. I will let you know tomorrow after I put them in. take some pics when u are done, and how high are u looking to go
carnuck Posted February 11, 2007 Posted February 11, 2007 Aren't the springs different lengths short to longbox?
DirtyComanche Posted February 11, 2007 Posted February 11, 2007 Aren't the springs different lengths short to longbox? Nope.
BARILLMS Posted February 11, 2007 Author Posted February 11, 2007 XJ rears are 52" MJ rear are 57" eye to eye. Full size waggys are also 57" is this correct?
feerocknok Posted February 12, 2007 Posted February 12, 2007 One of the J trucks has something ridiculous like 67 or 69" leaves
