Dana 30 swap
I'm toying with the idea of swaping in a different D30 instead of changing the gears in the one I've got. I can pick one from the U-Pull-It for $40-50, which is much less than the parts and labor for new gears. Can I upgrade to one without the vacuum disconnect 4wd? If so, how does the 4wd engage on it? Or am I better off staying with the vac system? I know I could just upgrade to the better shafts or u-joints, but what are the benefits and disadvantages of this? Any tech links?
Look for ABS. I don't remember which year was the start (89? 92?), but ABS XJs after that should have the 297 joints. And I think it's 97 where all XJs got the 297s. If anyone has the exact info, feel free to chime in. :D
Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 84-99 (some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints)
YJ is also low pinion AFAIK.
Nah. YJs are HP. They gayed over the TJ axles.
But he doesn't want the housing, jsut the shafts. I hope. Unless he likes leaf springs!
I thought he wanted the entire axle, so he wouldn't have to set up a different ratio in his front differential.
