Glenn Moyer Posted April 13, 2012 Share Posted April 13, 2012 Since the time I bought my 89 Comanche it's leaned to the left. Looks as though a 500# guy is sitting in the drivers seat. And NO I'm not that big! (yet)LOL It can't be in the suspension. I've replaced the front coils and also installed coil spacers. Put in a metric ton rear spring pack with a dana 44 rear end. Drop shackels. And there is still a 1.25 difference between the left and right side. Exactly the same difference between the front and rear. I got these measurements from the floor to the center bottom of the wheel flares. Any help? Thanks Glenn Link to comment Share on other sites More sharing options...
SW86 Posted April 13, 2012 Share Posted April 13, 2012 i had a lean on the drivers as well ever since i put on my 4.5 rough country/hell creek lift. i finally stepped up to 6.5 coils and shocks and it was gone. so it wasnt hell creek springs. it was $#!&ty RC products. my driver shock had to of died instantly. so id suggest checking those out. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted April 13, 2012 Share Posted April 13, 2012 Since the time I bought my 89 Comanche it's leaned to the left. Looks as though a 500# guy is sitting in the drivers seat. And NO I'm not that big! (yet)LOL It can't be in the suspension. I've replaced the front coils and also installed coil spacers. Put in a metric ton rear spring pack with a dana 44 rear end. Drop shackels. And there is still a 1.25 difference between the left and right side. Exactly the same difference between the front and rear. I got these measurements from the floor to the center bottom of the wheel flares. Any help?Thanks Glenn It HAS to be the suspension...somewhere. Check those drop shackle angles on both sides. Are they the same. Measure from the center of the wheel to the flare instead of the ground. The surface is relative, distance from the wheel is more telling. I'd check for a missing or broken leaf...or maybe a missing or collapsed coil isolator. Then start looking at your "uni-frame". Look between the cab and bed for a bend or break in the frame rail. Look at your front leaf mounts too, bushings?? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 13, 2012 Share Posted April 13, 2012 Since the track bar attaches to the left side, sometimes it will pull the left side down a bit, all you can do is try to add an extra isolator or two to the driver side and hope for the best. Link to comment Share on other sites More sharing options...
johnr Posted April 13, 2012 Share Posted April 13, 2012 mine did the same when i bought it with the stock springs. i was hopeing it would go away once i upgraded but its still there and i replaced everything and the frame has no buckels or brakes but i think the back end may be tweeked . with the bed off and the rear axle on jack stands there it 1.5" differance from the rail bottom to the ground. Link to comment Share on other sites More sharing options...
Joe Posted April 25, 2012 Share Posted April 25, 2012 My truck has the same problem. I just figured that was the side the gas tank is on amd the driver. but who knows. Link to comment Share on other sites More sharing options...
tralfaz Posted April 25, 2012 Share Posted April 25, 2012 Since the time I bought my 89 Comanche it's leaned to the left. Looks as though a 500# guy is sitting in the drivers seat. And NO I'm not that big! (yet)LOL It can't be in the suspension. I've replaced the front coils and also installed coil spacers. Put in a metric ton rear spring pack with a dana 44 rear end. Drop shackels. And there is still a 1.25 difference between the left and right side. Exactly the same difference between the front and rear. I got these measurements from the floor to the center bottom of the wheel flares. Any help?Thanks Glenn It HAS to be the suspension...somewhere. Check those drop shackle angles on both sides. Are they the same. Measure from the center of the wheel to the flare instead of the ground. The surface is relative, distance from the wheel is more telling. I'd check for a missing or broken leaf...or maybe a missing or collapsed coil isolator. Then start looking at your "uni-frame". Look between the cab and bed for a bend or break in the frame rail. Look at your front leaf mounts too, bushings?? My 88 has a 1/2 lean on the driver's side as well. I am pretty sure it is the coil spring isolator because it looks pretty well compressed compared to the passenger side. How hard is the isolator to remove? Link to comment Share on other sites More sharing options...
ParadiseMJ Posted April 26, 2012 Share Posted April 26, 2012 It is not at all hard to remove/replace the isolater. Removing the coil spring is a bit of a task though, and you have to remove the spring to get the isolater out...so while you're in there...you may as well do it all, new isolaters, both sides. It'll ride a bit (and I emphasize a BIT) smoother. Link to comment Share on other sites More sharing options...
tralfaz Posted April 26, 2012 Share Posted April 26, 2012 It is not at all hard to remove/replace the isolater. Removing the coil spring is a bit of a task though, and you have to remove the spring to get the isolater out...so while you're in there...you may as well do it all, new isolaters, both sides. It'll ride a bit (and I emphasize a BIT) smoother. I've actually done a spring swap on a ZJ so I don't think that will be a big issue. I have replacement springs and will replace both isolators as well. I'm sure the ride won't change much but I can't stand the 1/2 inch left side lean. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted April 27, 2012 Share Posted April 27, 2012 I can't stand the 1/2 inch left side lean. That's what she said!!! :brows: Link to comment Share on other sites More sharing options...
vaquaro Posted April 27, 2012 Share Posted April 27, 2012 :D I tend to lean to the Left myself , I think it's a west-coast thing , being on the left side of the map and all ...... Link to comment Share on other sites More sharing options...
johnr Posted May 8, 2012 Share Posted May 8, 2012 same springs with a new to me 8.8 axle and the lean is all gone :clapping: . could it be that the d35 was bent :dunno: ill check ferther and get back Link to comment Share on other sites More sharing options...
MTBTyler Posted May 17, 2012 Share Posted May 17, 2012 this happened to me after lift. It was the first time ive lifted anything. My one coil wasnt all the way into the groove on the axle. Link to comment Share on other sites More sharing options...
Harley Posted May 17, 2012 Share Posted May 17, 2012 "Looks as though a 500# guy is sitting in the drivers seat" Marry a fat girl and go cruising. It should level itself out within a few weeks. :thumbsup: Link to comment Share on other sites More sharing options...
mountainman Posted June 21, 2012 Share Posted June 21, 2012 I'm going for the "gas tank side and typically only driver in car" its whole life scenario. Cause mine leans too, yet the whole truck is super clean one owner. And the PO only weighs prob 180 lbs. My plan is to swap the front coils from left to right when i lift it. Been also trying to keep my ice chest on the pass side of the bed up toward the front. That seemed to help when the ice chest was loaded. Link to comment Share on other sites More sharing options...
xjrev10 Posted June 21, 2012 Share Posted June 21, 2012 Its a jeep unibody thing. I have owned XJs that have done that as well. My guess would be the trackbar. Find yourself a plus size to ride shotgun with ya. Problem solved. :D :eek: :wrench: Link to comment Share on other sites More sharing options...
jimoshel Posted June 21, 2012 Share Posted June 21, 2012 Depending on which way the wind is blowing determines which way my Jeep leans. Link to comment Share on other sites More sharing options...
