skidoo_j Posted April 10, 2012 Share Posted April 10, 2012 After lots of research looking over any and all fabricated bumpers I started templating my bumper out of cardboard. I wanted it to be unique and not just have a tube across the front. It has a receiver up front and I'm starting on the rear this week. Here's some pic's of the process... I did buy the frame reinforcements from jcroffroad, and had fitment issues with the steering brace. Link to Hosted photos. Fender Cut: Fitting the wrap templates: wrap around welded: need to fill in voids in welds prior to paint and finish. Will post pics once painted installed and then rears... *edited to change title Link to comment Share on other sites More sharing options...
SW86 Posted April 11, 2012 Share Posted April 11, 2012 looks good but why mount the D tabs down so low? seems like that would be an issue in some situations. Link to comment Share on other sites More sharing options...
skidoo_j Posted April 11, 2012 Author Share Posted April 11, 2012 looks good but why mount the D tabs down so low? seems like that would be an issue in some situations. A few reasons. The first was so that the front of the truck didnt have a knee catcher. We thought that if the they were in use it would be during recovery, so them being lower would give it more lift. but probably the biggest thing was when tieing them in to the brackets if they were welded to the face there would not have been enough room between the tab and the 2.5" tube to make a solid weld. I don't foresee them providing any clearance issues unless they'd snag on something, but if there were the case I think it would be beyond the capabilities of the truck. Link to comment Share on other sites More sharing options...
H3RESQ Posted April 11, 2012 Share Posted April 11, 2012 looks good but why mount the D tabs down so low? seems like that would be an issue in some situations. A few reasons. The first was so that the front of the truck didnt have a knee catcher. We thought that if the they were in use it would be during recovery, so them being lower would give it more lift. but probably the biggest thing was when tieing them in to the brackets if they were welded to the face there would not have been enough room between the tab and the 2.5" tube to make a solid weld. I don't foresee them providing any clearance issues unless they'd snag on something, but if there were the case I think it would be beyond the capabilities of the truck. Those are ledge grabbers for sure on rocks. There probably fine on soft terrain. Those will hamper a climb well before its beyond the rigs ability. Bumper does look good. Link to comment Share on other sites More sharing options...
skidoo_j Posted April 12, 2012 Author Share Posted April 12, 2012 looks good but why mount the D tabs down so low? seems like that would be an issue in some situations. A few reasons. The first was so that the front of the truck didnt have a knee catcher. We thought that if the they were in use it would be during recovery, so them being lower would give it more lift. but probably the biggest thing was when tieing them in to the brackets if they were welded to the face there would not have been enough room between the tab and the 2.5" tube to make a solid weld. I don't foresee them providing any clearance issues unless they'd snag on something, but if there were the case I think it would be beyond the capabilities of the truck. Those are ledge grabbers for sure on rocks. There probably fine on soft terrain. Those will hamper a climb well before its beyond the rigs ability. Bumper does look good. I guess it's possible to snag on something. I'd say they're still higher then the ones on an arb winch bumper because of the angles and size. I plan to place the ones on the rear on the vertical as the hitch will protrude past the tabs. Although they may end up on the angle as well because i'm trying to figure out the best way to inset the license plate so it doesn't look like an after thought. Link to comment Share on other sites More sharing options...
skidoo_j Posted April 13, 2012 Author Share Posted April 13, 2012 Painted and mounted. Rear templates being made. I'm thinking it'd would have to be a boulder for the tabs to catch anything. or near a 60 degree incline. rear to match same lines but not wrap. Link to comment Share on other sites More sharing options...
SW86 Posted April 13, 2012 Share Posted April 13, 2012 your moving along nicely. can't wait to see the whole truck when their done :thumbsup: Link to comment Share on other sites More sharing options...
skidoo_j Posted April 21, 2012 Author Share Posted April 21, 2012 Fabing the rear bracket from pictures and fit. I made an 1/8" plate washer to make the mounting plate flush to the shackle bracket. used 2.5" 3/16" tube and 7"x3/16 steel i went past the 4th bolt to possibly weld a piece of angle to apply torsion on the frame or add a bolt in the oblong in the frame later if needed. cardboard templates to transfer the holes to the steel used ball peen hammer to transfer. primed passenger side installed. **edited to change photo host Link to comment Share on other sites More sharing options...
RockMJ Posted April 21, 2012 Share Posted April 21, 2012 Fantastic work man. I'm seriously looking forward to seeing how the rear one comes out! I would have to agree with those d-ring tabs hanging down really low but if it works, it works. Great work RockMJ Link to comment Share on other sites More sharing options...
skidoo_j Posted April 21, 2012 Author Share Posted April 21, 2012 The one thing I've decided though is that cardboard is great for transfering bolt lay outs, but horrible for making true templates. It needs to be something a bit more rigid. Although I guess having to grind an 1/16 to an 1/8" off for clearance isnt bad. The spot that upset me the most though is the bottom of the rear bracket, I had followed the entire shackle bracket, but then when it was made into steel the taper is off, I guess I could have screwed up when cutting with the plasma, but I made changes for the driversside template. Link to comment Share on other sites More sharing options...
Alexia Posted April 21, 2012 Share Posted April 21, 2012 Those are so nice people are going to start asking you to make them rear bumpers. :P Link to comment Share on other sites More sharing options...
skidoo_j Posted April 24, 2012 Author Share Posted April 24, 2012 Got the driverside bracket made and installed... Much cleaner then the passenger. The driverside is presentable. It even bolted up easier. Now I start on the bumper itself. 90 degree days in scalding sun is worse then dealing with rain and wind :( The steel gets so hot just sitting in the sun everything gets handled with welding leathers. Link to comment Share on other sites More sharing options...
knever3 Posted April 24, 2012 Share Posted April 24, 2012 Sweet work!! :bowdown: Link to comment Share on other sites More sharing options...
skidoo_j Posted April 28, 2012 Author Share Posted April 28, 2012 Rear bumper all welded... Only grinding, maybe some fill welds, and painting. Will of course post pics of the whole truck once installed as requested. no the bumper doesn't float. :) They were rotated as it was easier to turn the picture then flip the bumper. end profile Link to comment Share on other sites More sharing options...
skidoo_j Posted April 29, 2012 Author Share Posted April 29, 2012 I cut off the support jig and it mounted right up. :) Link to comment Share on other sites More sharing options...
skidoo_j Posted May 4, 2012 Author Share Posted May 4, 2012 The completed shots. i may add a brush/bull bar type to the front to give it a little more attitude but i'm done for now except mounting a horn some where. Link to comment Share on other sites More sharing options...
H3RESQ Posted May 5, 2012 Share Posted May 5, 2012 Bumper got a nice look to them. use a thicker coregated cardboard and templates will match in size better next time. Style and shape of bumpers is great, just don't dig how low front tow hooks are and the rear license plate has same issue for me. That license plate will be toast if you actually wheel the truck. It just seems clearanc for real world wheeling was the afterthought. beautiful bumpers and fab work all the same buddy. Maybe ill see you on the trail in browns camp sometime! Link to comment Share on other sites More sharing options...
jakeWI Posted May 6, 2012 Share Posted May 6, 2012 really like that rear bumper Link to comment Share on other sites More sharing options...
skidoo_j Posted May 6, 2012 Author Share Posted May 6, 2012 Bumper got a nice look to them.use a thicker coregated cardboard and templates will match in size better next time. Style and shape of bumpers is great, just don't dig how low front tow hooks are and the rear license plate has same issue for me. That license plate will be toast if you actually wheel the truck. It just seems clearance for real world wheeling was the afterthought. beautiful bumpers and fab work all the same buddy. Maybe ill see you on the trail in browns camp sometime! the front plate is just zip tied to the front cowl right now. I plan to make a bracket that fits in the receiver. Then when i get around to making the winch bracket i'll make some sort of dual purpose connection so i could leave the winch in the front and attach the plate to it too. The rear plate is sunk into the rear bumper and the exhaust pipe comes out below the plate. I guess you could say clearance was an afterthought because I was designing them to conceal the tubes for my hitch and winch as well as the looks were more in the design then rock crawling clearance. I don't ever plan to go bigger then the 31" tires that are on it now... I know the front tabs are low, but when compared to the approach angle of my bumper vs an arb winch bumper i've got a more vertical angle. My brother has the arb bumper on his xj. I also wanted to be able to push some one with out gording their rig. I think I even used some of your bumper work/photos for ideas. You have the grey truck with the dimpler and the rock guards that wrap up after the door, I think you welded them to the truck and were selling that awesome rear bumper, but you'd cut into the bed right? If I"m thinking right your lines and pieces were cut a hell of a lot better then mine, I free handed all the cuts with a plasma and don't have a metal break so each angle is a cut piece welded at the angle. I don't know if I'll drive up to browns for awhile with the comanche. My brother still lives in portland and we've been using the corolla when we go with gas prices the way they are. really like that rear bumper Thanks Link to comment Share on other sites More sharing options...
H3RESQ Posted May 6, 2012 Share Posted May 6, 2012 I have my rear license plate on a bracket that slides in reciever hitch now, works great. Your bumpers (especially rear corners) look great and have a cool shape to them. I like that you took the time to add some shape/style to them. Ya, on my rear we used a band saw to cut the pieces out so grinding was less than with a plasma. The reason I mentioned thicker carboard is because with thin cardboard the templates always end up to large. I didn't end up selling the rear bumper, so I'm actually still running it and the bed. I tossed the bed I bobbed. Link to comment Share on other sites More sharing options...
skidoo_j Posted May 6, 2012 Author Share Posted May 6, 2012 I have my rear license plate on a bracket that slides in reciever hitch now, works great. Your bumpers (especially rear corners) look great and have a cool shape to them. I like that you took the time to add some shape/style to them. Ya, on my rear we used a band saw to cut the pieces out so grinding was less than with a plasma. The reason I mentioned thicker carboard is because with thin cardboard the templates always end up to large. I didn't end up selling the rear bumper, so I'm actually still running it and the bed. I tossed the bed I bobbed. Well i really do like your rear bumper probably more then mine, i really liked the wrap on it, I just didn't want to cut my bed up and by the time i cut it up and lowered the ends, it probably would have been too low hence why I didnt wrap my rear. .... Well I'm glad you're still running it though. It really is nice and if you'd a sold it they probably wouldn't have appreciated the amount of work into it. I'm debating on doing sliders. About how much do you think your sliders weigh or about how much material did you use. What gauge tube did you use.. I'm also looking into a custom bull guard too. although i think painting the entire truck is more important. Link to comment Share on other sites More sharing options...
RockMJ Posted May 6, 2012 Share Posted May 6, 2012 Would you be willing to make another rear bumper for a fellow member? Hmmm :D ? I really love the look man, super sexy RockMJ Link to comment Share on other sites More sharing options...
skidoo_j Posted May 6, 2012 Author Share Posted May 6, 2012 Would you be willing to make another rear bumper for a fellow member? Hmmm :D ? I really love the look man, super sexy RockMJ If you were more local so you'd be helping probably. But to be honest i don't have any sort of connection on steel so i have about 325 in steel for front and rear, and all the wire and gas. my guess is i probably paid over 200 per bumper in materials by the time i account for the grinding wheels etc. Freight would probably be expensive too. Link to comment Share on other sites More sharing options...
