86 with a 95 dash & 4.0L
Auto
90k on the body
150k on the engine
Needs a new crank sensor before i can drive it >_<
Very little body damage (Just a few dents on the front right & Tailgate)
Very little rust, Just a little on the floorboard
can't wait to start tearing into it :wrench:
So much $#!&amp; everywhere.. Literally...
It was sitting at a dairy farm, So there's chunks of manure here & there inside (no carpet) And a few disgusting mouse nests.
Just finished taking out the chairs, Gonna re-paint the floor
I'll take a few pics if you guys want
(this should probably be moved to the project section lol)
I kinda like that brown. How bout some daylight shots.
I'll get a few tomorrow, If i get a chance.
Wish i could get the dang thing to run
He's in Bellingham, Washington during winter season. There is no daylight! :D
:rotf:
So true.
At least it quit raining long enough for me to crawl under & swap out the Cps (although that wasnt what was wrong with it >_< )
no body can have just one ! comanche.gif :banana:
Why not? or,,you got that right. Been talking to a guy about his '91 Eliminator. If I can get him down a couple hundred it'll make my 15th. To the best of my knowledge that will leave only 2 MJ'S in Pueblo county not in my yard.
:rotfl2:
Sat at a red light near seattle, Next to another comanche.
He smiled And gave a big 'ol thumbs up :cheers:
Also; For The ecm, Do you HAVE to program it with your vin? Or can i get one from the junk yard out of a same year cherokee/comanche & Plug it in and have it work?
fml
friend helped me unload some spare interior parts into the jeep
and out of habit he locked the door
I have no door key >_________<
fml
Break the passenger or driver window if you have to. Stupid easy to replace, and usually dirt cheap.
Or, if you are like the majority of us, reach up from the bottom, push the carpet over, and unlock the door.
Rob
fml
Rob
I just twist the vent window open with my thumb. :doh:
Got a pic of your engine compartment?
You said dash and 4.0 from a 95, that probably means HO, then you would need a ECM from a 95 Cherokee.
Do you know if it is an HO conversion? I would assume a conversion of some type because the 4.0 wasn't available in 86.
Check all your fuses, relays and grounds to help eliminate possible causes of your no start situation.
fml
Rob
Thats what i did on my other comanche when i locked myself out, But this other one doesnt have them :/
Got paid & Went to the part store, Came back swapped out the plugs / wires / cap /roter / Sensor thinger in the distributor .. Turned it over & she fired on up like a champ
Tomorrow i'll be finishing tearing out all the interior & Remove some rust / Paint the floor / clean / put everything back in.
Havent had any time / good weather to work on it till this week, Hope i get a $#!&amp; ton done.
:agree: I now have three :jump: :jump: comanche.gif
Some people just get greedy when it comes to collecting. :D
Got 95% of the interior done.. Just need to get some screws for the trim & two more seat belt bolts & finish bolting down the seats in the morning.
