Truckcom Posted January 6, 2012 Share Posted January 6, 2012 After years of problems with my passenger door, on my 88 Pioneer, often refusing to unlock, I thought it time to fix the problem but I couldn't get the door opened to pull the panel. Finally after repeated attempts the lock released and I was able to open the door. After removing the actuator I could find nothing wrong but observed the mechanism to be badly soiled with sticky gunk which I assume to be old grease maybe mixed with years of comtaminants. Could this be the problem? Has anyone else had this happen or should I look toward another cause? All linkages seem fine and apparently the inside of this door has never been accessed before. Link to comment Share on other sites More sharing options...
bgred2 Posted January 6, 2012 Share Posted January 6, 2012 Got the same problem with my 89. Will be watching.......... Link to comment Share on other sites More sharing options...
cocy Posted January 6, 2012 Share Posted January 6, 2012 that could be the problem, the other day my door would not open at all finally I slimjim the door open put some oil on every thing now door works like a champ. so I would clean and oil eveything then push the lock button back and forth with the door open see if it gets any better. Link to comment Share on other sites More sharing options...
Pete M Posted January 6, 2012 Share Posted January 6, 2012 had the same problem with my 88. a new lock mechanism cured it. :thumbsup: Link to comment Share on other sites More sharing options...
KYMJ Posted January 6, 2012 Share Posted January 6, 2012 Mine did it when cold, once warmed,ok. Got some off a 96 Cherokee. The passenger side is acting up again. They are available new from TeamCherokee. No amount of cleaning or lube helped mine. Link to comment Share on other sites More sharing options...
Truckcom Posted January 8, 2012 Author Share Posted January 8, 2012 OK, I think I have it working again. I soaked the incredibly sticky gunky lock mechanism for 2 days in the bottom of the parts washer, blew it out with air, sprayed it with aerosol grease and reinstalled it. It will still occassionally act up but if I snap the lock back and forth a time or two it works fine. If anyone else has this problem, it might be worth while trying to spray an aerosol solvent and lube into the latch as best you can and see if over time it may work itself back into the mechanism and hopefully better function. Removal of this latch is a pain in the Derriere and can stretch the vocabulary of the hobby mechanic. Link to comment Share on other sites More sharing options...
knever3 Posted January 8, 2012 Share Posted January 8, 2012 You can also get some liquid graphite from your local locksmith, it works wonders. You just spray it in the key cylinder and it usually frees it up. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 9, 2012 Share Posted January 9, 2012 I wonder if this works on a Comanche. Works killer on the 87 to 90 Cherokees!! http://www.naxja.org/forum/showpost.php ... ostcount=2 Link to comment Share on other sites More sharing options...
Truckcom Posted January 9, 2012 Author Share Posted January 9, 2012 I should have been more clear in stating my problem. This is not an electric door lock but rather manual and the lock set and the inside rocker function fine. The problem was in the mechanism that is part of the striker latch. I have never seen before the kind of the brown sticky gunk that must have inhibited the mechanisms function. I can only think this was the cause of the problem and must have been due to weathering of the original lube that was used 24 years ago. I know I'm not the only one who's had this problem and want to give a heads up to the others out there. Link to comment Share on other sites More sharing options...
