Distributor Noise
Symptom: "ert" - "ert" - "ert" loud chirping when first starting the motor
It goes away completely after a minute or so.
I thought it was the tensioner pulley at first, so I pulled it and replaced it
as it felt a little rough. No joy.
Got out the old shade tree stethescope (a 24" 3/8" drive extension) and probed
all the logical places. No joy.
Then I noticed the sound was well aft of the belt plane, and discovered it is
the distributor. I know they're not really rebuildable (based on parts manual
not listing any bushings/bearings). My question is, before I just go buy a new
one, are there any upgrade options, given the opportunity? Thanks!
Replacement dist on the way, will post results when done.
Very surprised, given the low mileage and easy life, but
stuff does wear. I know this dist has never been removed
so will be interesting to see if anything is missing. I'm not
sure how far (if at all) oil comes up the shaft, but my hunch
is a worn bushing that gets quiet after a minute of lubrication.
Could also be the thrust washer on the dist is MIA (between the gear and the housing)
dead on, i have had to replace two on 4.0L's you could have replaced, re worked yours but you will never hear the annoying squeek again by replacing it.
Well this has turned out to be a much greater debacle than I envisioned!
Got the new distributor today (Morris 4x4 - great folks - rocket fast shipment).
The swap was uneventful, but it ran like a dog for a couple minutes and quit.
I'm very confident I got it positioned correctly, but I rotated one spline in either
direction just to double check. Nothing. Want back to basics, pulled #1 plug,
rotated to TDC on compression stroke, and verified rotor pointing to #1 plug wire.
Triple checked wire firing order, 153624. Tested coil and shows strong spark.
Tested each plug wire and getting spark to each plug. I have ~40 psi fuel
pressure at the rail. No spit, no sputter, no nothing. CPS is nearly new.
Only fault codes are 12 (recently disconnected battery) and 52 (running rich)
What the Heck is going on here?!? :headpop:
BTW, the old distributor was so bound up internally I could hardly even rotate
the shaft by hand.
I looked at an XJ last week with a 4.0 and among several other problems the distributor shaft was bent to the degree that you could actually see the cap wobble as it ran.......also made a clicking noise similar to what you describe, couldn't imagine what bent the shaft.......I passed.
Just curious though......I have put the button in the wrong of three holes in a 4.0 dist and got a no start......could that be your case?
The button is old school term for the distributor cap center contact to the rotor. Since the cap is keyed to only install one way, ?? No idea about three positions.
Recheck the wires again to be sure, firing order 153624 and the distributor rotates clockwise. Sounds like it's not right.
http://tomasz.korwel.net/2006/12/19/rep ... l-engines/
If you look at pic 8 you will see other hole that look like knock-outs, the one to right of the button pin hole was open and I inserted the button pin in that one causing the no start.
Thanks for the replies, and for posting the dist. alignment process. I had
already worked through that via FSM, but those visuals are better. So here's
the rest of the story. After a bit of prayer, and a few hours sleep, clearer
thinking returned and I was led to look for really dumb simple stuff (those are
usually the gotcha's right?). Ive been messing with "button"s for many years
but never knew that term. I have a couple new, but unprintable, terms. Turns
out the metal tab that rides on the contact inside the cap had very poor, and
intermittent, contact. That's why I was able to see spark at plugs but no run.
Wasn't getting spark at every plug every time, but only every plug once in a
while. Didn't realize that when testing individually. Once I bent that thing
higher up, voila - running truck. I love simple solutions, but I love them a lot
more when they don't take all night. About the old distributor, I may be
able to resolve it by soaking in penetrant. There's a lot of gummed up fluid
inside, as if oil had found it's way all the way up the shaft over time and then
congealed. BTW this dist is a newer flavor with notched shaft so the button
can only go in one position. The older style has potential to install more than
one position.
one position.
Yes that's what I was getting at.
Glad you got it straightened out and running.
Well it's not over quite yet.
Now after ~600 miles, still have an intermittent miss that's
vexing me sorely.
Only happens between 2000 and 2500 RPM, moving down
the road. It's as if I turned off the key for `1/4 second,
like a quick cough. It happens about once every few miles,
whether or whether not under load. All the following are
new: coil, distributor, cap, rotor (button), wires, and plugs.
All connections to dist and to coil are clean and firmly tight.
Sitting still, I can rev it to redline repeatedly without a miss.
Have good fuel pressure and delivery, injectors nearly new.
Any ideas where the heck to go next? :hmm:
Mine did that for about a week then died completely. Turned out to be the ignition coil. It was a fairly new MSD coil too. Replaced it with the old original Mopar coil, it never happened again. Try a resistance check on the coil.
Ok, I've tested both coils, and both are within FSM spec. Primary at 1.1 ohms
and secondary at 11.5K ohms.
I keep reminding myself that my intent was improvement, by updating to the
newer intake and replacing a troublesome distributor. It's been all downhill
since then.
Intermittent miss, with all new ignition components, reworked head, and newer
intake. Also, when I suddenly release the throttle the idle drops to near zero.
The IAC is new and the TB is new and clean.
Idle vacuum symptom: Steady at 18-19, then slowly (15 seconds) climbs to 20,
the idle speed drops a couple hundred and the vacuum drops quickly back to 18.
Will do this pattern all day long, all by itself.
Will rev to redline smoothly (without load), but with load it sometimes sputters first.
No, I don't have AF meter yet, but plugs indicate reasonable mix (lt brown). (unlike
the black I got before backing off the AFPR).
I've checked and rechecked for intake leak with propane and no indication, but I'm
about ready to pull intake again just to look at the (new) gasket for any sign of
bypass.
Any other suggestions (not involving explosives) are most welcome!
And the outcome is...no joy.
No fault codes, other than 55.
I pulled the ECU plug, and found very little
oxidation. I treated both plug and all pins
to a liberal dose of "deoxit", and scrubbed all.
I verified all pins are correctly positioned, other
than the 10 of 60 not applicable to me (per FSM
schematic). I also verified continuity, and no
resistance, of the conductor (#19) between ECU
and coil. I even swapped in yet another, this time
OEM, coil. I still have a dramatic, and intermittent,
miss under load. When the miss happens the tach
also blips, suggesting to me this is electrical (since
tach feeds from ECU). The miss happens now at
2K(sometimes), 3K (nearly always), and 4K (sometimes)
RPM. Feels as if I momentarily unplugged the coil.
Yes, installing the "upgrade" intake manifold was the
genesis of my troubles. I am sorely regretting my
inability to resist the temptation. Could not leave
well enough alone. Lot's of new power, but a totally
unacceptable downside.
One interesting observation, the build of my truck is
11/91, but the sticker on the ECU is 01/93, suggesting
that it was replaced (warranty job?) during the first
year of operation.
I cannot imagine the ECU being the source of this issue,
particularly since it was initiated by a completely unrelated
(manifold) exchange, but I am rapidly running out of things
to suspect.
Also, not sure I mentioned this before, when I suddenly let
off the throttle while in motion the motor will nearly, and
sometimes actually, stall out. Idle is no longer reliable.
I used to count on my ability to diagnose/resolve stuff like this,
but not this time. Totally stumped. :hmm: :hmm:
Well, I'm stumped too. :dunno: I did this mod with absolutely zero problems, as well as many many others over on the stroker forum. It improved the idle immensely and it never missed under load. About 1K miles after, I hard-wired in a Unichip and then had it tuned and dynoed at Hesco. On the way home it skipped a couple of times under load (like the coil was unplugged momentarily) on long grades at about 2500 RPM. Brought it back to Hesco and they set the timing curve back a bit for that RPM range and haven't had a skip problem since. I did notice that after the intake manifold was installed and I disconnected the battery to do some electrical work, the ECU "learning curve" sometimes took up to 50 miles, longer than it used to. It never skipped, but the idle was low and it would stall at a stop at times. But after 40-50 miles or so, all was well.
I'm suspecting your ECU now. What's the number on it? I'd also ask this question over on the stroker forum - someone may have experienced similar problems after the intake swap.
My ECU is 56027396 (for 1992 manual 6 cyl).
Today I scoured the JY, and grabbed an ECU
from a 92 XJ, auto (all I could find) #56027488,
hoping for good interchange.
Well I put it in and truck runs like crap, even worse
than before. Plus triggers maint light. Stumble, miss,
cough, sputter, and stall unless I keep my foot on it.
Didn't see that one, was there a solution? I'm really doubtful the distributor could
be the culprit since it only has one correct position, and since the motor will rev
when sitting still, up to around 4K rpm before getting ratty. I swapped back in
my known good OEM CPS, to rule out a faulty replacement CPS, and no change.
I also found a connector under the ECU that plays in this circuit, opened it up
and found a bit of green,.Cleaned it well, but that wasn't the problem either. There's
an outfit I found online that offers an ECU testing/rebuilding service, but it's pricey
and I'm curious if anyone has used this service:
http://www.directauto.com/product-exec/ ... ng_Service
The want $100 to test, and $228 to repair if damaged. The ECU for automatic (488) doesn't
play nice in the manual, and I had no JY luck locating a 396 ECU to try. Over
on stroker forum there's some discussion about stumble @4200rpm due to
valve float, but those folks are running cams with rapid rise. My cam is, and
shall forever remain, stock.
